4e and 8 series drum unit
  • jwai
    • May 2018
    • 508
    Hi everyone,
    How to disassembly the drum out of the drum unit?
    Regards
    Re: 4e and 8 series drum unit
    Originally posted by jwai
    Hi everyone, How to disassembly the drum out of the drum unit?
    Regards
    most times you just have to sit down... and figure it out. UNLESS they are meant to be rebuilt, it is a trial and error job. If they are meant to be rebuilt it would be in the SM.
    • Bix
      • Apr 2018
      • 1421
      hello, is it possible to provide the reason? it's easy to make mistakes. Konica Minolta supplies the entire drum.
      • jwai
        • May 2018
        • 508
        Hi, since one 8 series had been scratched with one dot on the back side of drum with undefined reason, so I want to exchange the drum only with an used one on good condition.
        P.S. The machine only prints 2XX color counter.
        • tsbservice
          Field tech
          • 8007
          Exactly!
          It's a good idea to take shot drum unit and drill it BEFORE you really need to do it on life one
          I think I do it once before on 8series drum unit. There was some thinkering before I figure out how to unscrew drum from drum drive gear, though.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4679
            I rebuild all the 4 series drum units all the time. Not hard at all. Plus now all the parts are available, drum, blade, grid, sawtooth charge plate. Haven't done an 8 yet so not sure if the same. There are no instructions and not easy to explain so you have to wing it. Lay all parts out in order and reverse to reassemble.
            Maybe take apart a few bad drums first to see how it goes.
            • allan
              RTFM!!
              • 5462
              Exactly!
              Hehe one of those lefty tighty moves...
              Problem with replacing the cylinder and blade is by the time that seems like an option corrosion would have set in on the grid...
              Whatever
              • copier tech
                • 8142
                Hi everyone,
                Regards
                Done this a few times blue front cover off then 3 screws to remove the front bracket & unscrew the drive gear on the back.
                You can also fit black to colour just need to swap the chip & the front bracket.
                • jwai
                  • May 2018
                  • 508
                  Thank you all guys !!
                  • Bix
                    • Apr 2018
                    • 1421
                    A curiosity but .. Where can small spare parts be recovered? From other consumables used but in good condition? In the KM part list I don't find spare parts for drums/fusers. For example, to rebuild a fuser or drum, who do you supply from?
                    • tsbservice
                      Field tech
                      • 8007
                      Open Aliexpress, in search put ie. DR-512K, voila.
                      • tsbservice
                        Field tech
                        • 8007
                        Open Aliexpress, in search put ie. DR-512, voila.
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4679
                          No OEM parts available. Have to use aftermarket mostly from China. I use Copylite.com here is USA. Maybe they ship to your country?
                          • lazymangr
                            • Feb 2017
                            • 115
                            hey. have anyone found spare parts for the color drums holder-spacer so i can add black drums on color unit but build them in the office and not in customers office?
                            • tsbservice
                              Field tech
                              • 8007
                              On new black drums KM changed that part and now you cannot exchange end parts just like that.
