bizhub c454e problem with fw update
  • Proffice
    • Oct 2019
    • 11
    Hello guys. I have a problem with a bizhub c454e.
    I tried to update the firmware from F000-GD2-K2 to F000-G20-M1.
    All the other parts are updated, but the error "Download N.G." appears in the MFP Controller update.
    Therefore the machine, when i try to start it, shows me the message
    "Error, this is invalid external error. Please make sure the External Memory"
    and does not open.
    I admit I'm lost. Any suggestions?
    • 23009
    Re: bizhub c454e problem with fw update
    I'm thinking that your firmware was corrupted. I think that I would initialize the MFP board and re-load the firmware. If you haven't done it before it's a bit of a long drawn out process. I spent about half a day the first time:
    • copyman
      Owner / Technician
      • Sep 2005
      • 4724
      Agree with BC. I've had this before as well. I finally loaded the F/W in steps. Went back about 4 older F/W and loaded one at a time until the latest M1 F/w was installed. Also if you keep the USB service port open with NO flash drive installed machine will boot up to ready. That port door actuates a photo sensor and not sure why it boots up when open.
      • Proffice
        • Oct 2019
        • 11
        Thank you in advance guys. I will first try the older FW and I will give you feedback.
        • Proffice
          • Oct 2019
          • 11
          I finally managed to install the initial firmware of the machine, so it
          boots up just fine. I don't dare to update the firmware.
          Thank you guys for your help.
            • 23009
            Congratulations on your success! =^..^=
            • copyman
              Owner / Technician
              • Sep 2005
              • 4724
              You will still need the latest F/W for a lot of issues that F/W corrected over life of copier, office 365 scanning will not work, etc unless F/W is updated. Like I mentioned in previous post I have updated F/W in steps after the issue like you had and always worked.
