Konica Minolta c203
  • Anthony mazimum
    • Feb 2019
    • 9
    Konica Minolta c203
    My konica Minolta c203 complains of replacing the transfer belt unit, I replaced the sensor and the transfer belt but the problem still persists. But the transfer belt works in another machine.
    Urgent answers needed please. Thanks
  • Woxner
    • Jul 2011
    • 853
    Re: Konica Minolta c203
    replcace the fuse on the belt and reinstall. it works on another machine because the counter is different from the other belt . if fuse wont blow check icp on the board. also you must use the proper rated fuse. if you have the proper firmware you can set this to no stop
    • Anthony mazimum
      • Feb 2019
      • 9
      Plz where is the icp located on the board & how can I set it to no stop. If possible describe with images.
      Thank you!
      • Bix
        • Apr 2018
        • 1421
        Service mode
        • copyman
          Owner / Technician
          • Sep 2005
          • 4765
          Thank you!
          Make small donation to this site and request service manual. No way to explain with pictures, etc.
