Bizhub 284e loses IP address
  • Proffice
    • Oct 2019
    • 11
    Good evening from Greece guys.
    I have a problem with a bizhub 284e.
    When the customer switches off the main swith, the machine lose its IP address.
    It has happened before with a 224e, which occasionaly loses IP during weekend breaks...
    Any suggestions?
    • 23009
    Re: Bizhub 284e loses IP address
    Is it set to DHCP or Static? =^..^=
    • emujo2
      • Mar 2017
      • 1579
      Possible battery backup issues...This is pretty old E
      • Synthohol
        Certified Konica Expert
        • 5853
        The nvram is an ssd. There is no bettery.
        I suggest doing a network initialize and set a static address DNS and all.
        • Proffice
          • Oct 2019
          • 11
          It is set to static.
          I'll initialize the network and I will give you the feedback guys.
          • rrrohan
            • Sep 2011
            • 1977
            when you say it loses IP what does it revert back to?
            i thought default would be for it to go onto dhcp
            If its going onto dhcp then just reserve it that address in server/router
            Does it also lose the smtp address?
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
