A5C10Y0-F000-GD1-A9 Locate the firmware.
  • xender79
    • Nov 2009
    • 47
    A5C10Y0-F000-GD1-A9.exe
    C224e SSD fails and firmware is essential. Please.
    wotjq79@naver.com
    wotjq2@gmail.com
  • copier tech
    • 8144
    Re: A5C10Y0-F000-GD1-A9 Locate the firmware.
    C224 SSD failed and requires firmware.
    wotjq79@naver.com
    wotjq2@gmail.com
    What fault do you have?
    Assuming this is a C224e If your machine is on a continuous boot loop you will need to replace the SSD.
    • escalante
      • Sep 2018
      • 115
      Re: A5C10Y0-F000-GD1-A9. Please help me find the firmware.
      Good afternoon. The file weighs 339 MB it is not possible to send it by email
      Enviado desde mi SM-J701M mediante Tapatalk
      • collaudo
        • Jan 2020
        • 2
        Good morning. I introduce myself. I work in a company and We have been using a Bizhub c224e.
        I need to install the A5C10Y0-F000-GD1-A9.exe firmware.
        Is it possible to get a copy on google drive or onedrive ???
        we have problems with the LAN card and hard reset or other solution are not solved the problem!
        Thanks !
        Mr. Biagio
          use "WeTransfer - FREE" up to 2gb transfer and doesn't require files to be zipped
          it free - fast and easy to use!
          WeTransfer
          • emujo2
            • Mar 2017
            • 1579
            Thanks !
            Mr. Biagio
            1st, start your own thread..2nd what is the actual problem and why do you feel firmware will correct it? E
            • copyman
              Owner / Technician
              • Sep 2005
              • 4700
              3rd, make a small donation to this website to keep it going and many members here will be glad to send firmware, manuals. Other than that most will only offer FREE tech support.
              Thanks for helping to keep this site going !!!!
              • collaudo
                • Jan 2020
                • 2
                Sorry for the mistake: I was careless!
                About the firmware... I want try to downgrade my current version, because network adapter often "turns off" itself (no light, no networking signal).
                This after last firmware update (two months ago)...
                Thank a lot for your suggestions
