BH-C-360, external box function settings
  • tsbservice
    Field tech
    • 7951
    #16
    Re: BH-C-360, external box function settings
    Authentication Device 1 & Authentication Device 2 will make that option disappear. I think that I'd check Stop 9 Vendor Mode.
    Reading Manual never hurts. I think we have winner here.
    • Hansoon
      • Sep 2007
      • 3363
      #17
      Thanks Cat, yes I was thinking along the same lines since this machine had originally a card reader but I cannot find a way to turn it off. How to get rid of all this Authentication/Management stuff?? Would be convenient to know how to reset the complete machine back to factory defaults. Initialization doesn't do it.
      Hans
      “ Sent from my Intel 80286 using MS-DOS 2.0
      https://www.copytechnet.com/images/smilies/biggrin.png
      • tsbservice
        Field tech
        • 7951
        #18
        Hans
        Hans what type of Initialization did you do? [Clear All Data] from service mode?
        • Bix
          • Apr 2018
          • 1421
          #19
          Hi, I believe it is not possible to reset the Service Mode settings.
          The only settings you reset are those related to the CSRC when you initialize the network settings. I therefore recommend that you take a look at the one from @blackcat4866
          Also take a look at the Biling settings. They are often modified for some customers. Go to Service Mode> Stop> 9> Authentication Device (check also Counter Setting)
          • Hansoon
            • Sep 2007
            • 3363
            #20
            Yes, that's what I did as well as HDD format and Firmware. Since days I'm roaming in the Stop-9 settings but find it hard to find a way to find back to standard factory settings.
            I just want to get rid of this Authentication/Management crap. It is rather hard to understand the manual. It would take time to absorb whats written there and that's what I don't have. Machine has to go out tomorrow morning.
            Hans
            • tsbservice
              Field tech
              • 7951
              #21
              Strange, manual states that [Clear All Data] should clear/initialize Billing Settings/Management Function Choice.
              Go to Billing Settings/Management Function Choice if it's Card, can you revert to something else?
              • Synthohol
                Certified Konica Expert
                • 5777
                #22
                You can try and uninstall the card reader driver.
                Go to install data or driver install and uninstall whatever is in there.
