BH-C-360, external box function settings
  • Hansoon
    • Sep 2007
    • 3381
    Machine does not show "External Memory Document Scan" (Administrator Settings>System Setting>UserBox Settings>External Memory Function Settings)
    In the menu are "Save Document" and "Print Document" present but the 3rd entry "External Memory Document Scan" is missing.
    HD is present and active and had a logical format, FW is the latest and greatest. Any ideas please?
    Hans
  • tsbservice
    Field tech
    • 8007
    Re: BH-C-360, external box function settings
    I have no idea. Wild guess, compare soft switch settings with working machine. Sorry not much help.
    • Synthohol
      Certified Konica Expert
      • 5822
      enable it in admin mode user box settings ext memory settings
      • Hansoon
        • Sep 2007
        • 3381
        Err... Well that's exactly what I did from the beginning and the reason how I discovered that this 3rd menu item is not present.
        I did: Administrator Settings>System Setting>UserBox Settings>External Memory Function Settings
        In the menu are "Save Document on/off" and "Print Document on/off" present but the 3rd entry "External Memory Document Scan" is not there where it usually is.
        See my original post
        Hans
        • Hansoon
          • Sep 2007
          • 3381
          For sure an undocumented safety option made by soft switch setting.
          My own office machine has under External Memory Function Settings this 3rd setting "External Memory Document Scan" The other one coming from a wholesaler not. One would need help from KonicaMinolta but I'm an Indy........
          Really don't know how I can compare softswitches between machines.
          Hans
          • copyman
            Owner / Technician
            • Sep 2005
            • 4679
            Hans
            Hey Hans,
            Hope all is well. If you print out management list from both machines all the settings including softswitches will be on the pages that print. You can put mang lists side by side and go down the setting one by one until you see what setting is different.
            • Hansoon
              • Sep 2007
              • 3381
              Hey Copyman, I'm OK, thanks for asking.
              In the Management list I cannot find any soft switch setting. However in the Parameter list are many entries from soft switches but its under a header named FAX_JOB.data. Is that the one you mean?
              This machine is anyway different than all the other I have seen. When I put an USB-Stick in the port than it says:
              "An external memory is connected. The external memory can be accessed from the Systems User Box function"
              That's very different than usual. Normally it gives you the 3 option buttons:
              "Print a document from External Memory" or
              "Save a document to External Memory" or also
              "Save a document from External Memory to a User Box"
              I tried Initialization and also new firmware. It stays the same.
              Hans
              • tsbservice
                Field tech
                • 8007
                Hey, that will be rookie mistake, even I know how and where to enable USB memory...and when it comes to KM I'm de facto tenderfoot
                • tsbservice
                  Field tech
                  • 8007
                  Hans
                  Hans, you can save two machines MMLs on external memory, then compare them by little tool or print them and compare visually.
                  • Hansoon
                    • Sep 2007
                    • 3381
                    Yes, but I cannot find those soft switches. Only those under "FAX_JOB.data" when I call up the parameter list, not the Management List.
                    Hans
                    • tsbservice
                      Field tech
                      • 8007
                      OK, I opened SM and here is what I found:
                      • Hansoon
                        • Sep 2007
                        • 3381
                        Could imagine that it has something to do with "Management Function Choice" will have to dig in the manual Monday morning. Now it's Sunday evening here and I'm fed up. Sigh.
                        Hans
                        • Synthohol
                          • 5822
                          does the copier have a HDD installed?
                          if not i wonder if thats killing the option?
                          • tsbservice
                            Field tech
                            • 8007
                            Hans
                            From what I've reading machine has HD, which I suppose to be HDD
                              • 23006
                              Authentication Device 1 & Authentication Device 2 will make that option disappear. I think that I'd check Stop 9 Vendor Mode.
