bizhub c364e jam first tray
  • brent
    • Nov 2008
    • 1212
    It is probably silly but its plaguing me I have replaced the feed tires. I have the 2 black feed round clutches on order but I can only get about 17 or co copies out in between jams.. tray 2 is fine tray one is set to legal.. and it kind of rips the paper where the feed tires sits..
    can someone help me with this silly problem?
    brent thank you
  • Max
    • Oct 2011
    • 555
    Re: bizhub c364e jam first tray
    Try the torque limiter on the sep tyre. Has pressure of sep tyre been changed? Replace the black vertical guide as it can wear out/get notches from paper. Feed clutch sticking ?
      • 23006
      Jam code?
      • nelo
        • Apr 2019
        • 32
        brent thank you
        I had the same issue with a C224e. I resolved the issue by replacing the paper feed clutch. And on a 454e, I had to disconnect the paper feed clutch connector and reconnect the connector which fix the tray 1 paper jam issue.
        Regards
        nelo
        • copyman
          Owner / Technician
          • Sep 2005
          • 4665
          Make sure the plastic tabs arent broken where hooks on side door latch. I've been finding a lot of these broken affecting only one tray.
          • brent
            • Nov 2008
            • 1212
            sorry I forgot to respond back.. it was a clutch.. these machines are so good that I had never had the whole feed assembly
            out before.. clutch fixed it.. thanks
            brent
