cannot turn off separate scan when using glass
  • adecanmin
    • Oct 2010
    • 322
    Gentlemen.
    Customer was getting strange service codes. I upgraded the firmware. Fixed that problem. According to the customer before the upgrade, they could put the document on the glass, push start and it would copy. I made sure the separate scan was turned off when using glass. No good. I checked the pdf for the firmware about my issue. Nothing. I looked through service manual at soft switch settings. Nothing. Anyone run across this before?
    A
    • 30554
    Re: cannot turn off separate scan when using glass
    Did you reboot the machine? some settings changes machines need to reboot in order for the new settings to take to take.
    • adecanmin
      • Oct 2010
      • 322
      Yes. I'm going there today. I can restart it again.
      • mo0651
        • 1054
        Are you sure that "SORT" is not on???
        • adecanmin
          • Oct 2010
          • 322
          Sort is on. It has a finisher. I did turn that on recently. It was defaulted to group and non sort. Customer wanted it to sort as a default. I'll turn it off and see what happens.
          thanks.
          A
          • emujo2
            • Mar 2017
            • 1579
            sepscan2.pdf
            Might help..E
            • Bix
              • Apr 2018
              • 1421
              Hi, are you sure you haven't installed a special firmware? Do you remember the version?
              Also, manually it is not possible to remove the flag?
              • adecanmin
                • Oct 2010
                • 322
                Hello Gentlemen
                It was the sort function the was causing the problem. I put it on autosort and the problem is fixed. Thanks guys.
