Bizhub 35C-4 ?
  • mrfuser
    • 1626
    Bizhub 35C-4 ?
    Anyone know what this machine is? Client brought from another location and it has no labels anywhere and the print outs only say 35C-4
    is it a c353? C253?
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 35C-4 ?
    Now this is where a picture will help.
    Whatever
    • mrfuser
      • 1626
      Re: Bizhub 35C-4 ?
      OK picture of what it looks identical to a C3 53 but many machines of that year age do
      if there is a specific picture that you need to look at that will tell you exactly what it is tell me and I will take that picture
      • K-3
        service technician
        • Feb 2018
        • 51
        Re: Bizhub 35C-4 ?
        so there is no label on back that shows the serial # or machine id, can you print out a configuration page and see if machine model is listed there.
        • allan
          RTFM!!
          • 5462
          Re: Bizhub 35C-4 ?
          Then its a no-name rebrand. The serial number will give away the model.
          Throw some firmware at it...
          Whatever
          • copyman
            Owner / Technician
            • Sep 2005
            • 4785
            Re: Bizhub 35C-4 ?
            That's weird, it looks like an NEC model # but the C353 is IT35 C5. I've never seen a 35 C4 and no where on my cross reference lists. Does it have IT in front of #'s. Like the other poster said post a picture and we will figure it out.
            I'm sure most here know NEC designed the C253 and other color models. And Konica stuck with B&W. Not sure about now but back then NEC was making K/M color boxes.
            • mrfuser
              • 1626
              Re: Bizhub 35C-4 ?
              List print says serial number is 8030108
              • allan
                RTFM!!
                • 5462
                Re: Bizhub 35C-4 ?
                Yes that can be changed. Look for a serial number on the body.
                Whatever
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4785
                  Re: Bizhub 35C-4 ?
                  If you really want to solve the mystery post a picture! All I would need to see are a pic of front with door open & side door open
                  • 907tec
                    • 434
                    Re: Bizhub 35C-4 ?
                    Think it might be an Oce / Imagistics CM3522 (BH C353 cross). I have one out in the field somewhere, still.
                    • KMFLT3CH
                      • May 2017
                      • 242
                      Re: Bizhub 35C-4 ?
                      If you print out a config page it should say Generic 35C-4, which is a C353. You probably have the "planets" screen when booting up the machine, too. This is an easy fix:
                      1. Access the Service Mode.
                      2. Select System 2.
                      3. Select Software Switch Setting.
                      4. Enter Switch No. "10".
                      5. Bin Assignment "00000000".
                      6. Hex Assignment "02".
                      7. Click on Fix.
                      8. Click on End.
                      9. Power the MFP OFF/ON.
                      10. Print another Configuration Page. Page Header should now be changed to Konica Minolta.
                      Generic 20C-4 = C203
                      Generic 22C-1 = C220
                      Generic 25C-1 = C250
                      Generic 25C-4 = C253
                      Generic 28C-1 = C280
                      Generic 35C-3 = C352
                      Generic 35C-4 = C353
                      Generic 36C-1 = C360
                      Generic 35C-1 = C450
                      Generic 45C-2 = C451
                      Generic 45C-1 = C550
                      Generic 50C-1 = C650
