Bizhube 554e belt
  • Apach
    • 157
    Bizhube 554e belt
    Hi,
    Can the Transfer Belt assembly of c554 fit into the 554e?
    If can't maybe someone can give me a part number.
    Tnx
    There is no stupid question, just stupid answer
  • copyman
    Owner / Technician
    • Sep 2005
    • 4639
    Re: Bizhube 554e belt
    I thought the B&W and color were the same but after looking at part #'s it shows exclusive to the B&W 454e & 554e NOT color units. Learn something everyday. Probably would of known this but I have been rebuilding the trans belt units the last few years with new aftermarket belt & blade for under $100.
    454e & 554e transfer belt part # A61DR70022D
    • allan
      RTFM!!
      • 5462
      If the belt is the same lenght and the blade the same then you could build that over if you really want to take that risk.
      Best way is to try and shove it in there, would wonder if the retraction part for the color would be in the way...
      Whatever
      • tech51
        • 846
        • tsbservice
          Field tech
          • 7986
          Originally posted by Apach
          Hi,
          Tnx
          I would be more interested in opposite exchange
          For bizhub 554e part is:
          Intermediate ImageTransfer Unit - A61DR71311
          • Albonline
            • Sep 2008
            • 1144
            nope ,no color rollers or the retraction system on the mono unit.
            • Toxic
              • 697
              It makes sense...
              It is propably everything the same, just missing color rollers on bw type of transfer belt
              • larweedad
                • 92
                A color belt on a BW copier. I have done that without thinking. The copier still worked fine. The BW models do not have the color transfer rollers and now sensor lever for them. Just cost more the color.
                • tsbservice
                  Field tech
                  • 7986
                  O well stupid me
                  Belt only removed and cleaning section?
                  • Walterj
                    KONICA MINOLTA
                    • Jun 2017
                    • 89
                    Hi,
                    Tnx
                    good day
                    The transfer belt of a C554 color equipment has 4 rollers of 1st transfer one for each color
                    Monochrome 554e only has a 1st transfer roller
                    Regards.
                    • AL parts
                      • Jun 2019
                      • 61
                      The transfer belt of the C554 and 554E is the same, and the Transfer Belt Cleaning Blade is the same.
                      This transfer belt is also compatible with many models, C226/256/266, C227/287, C258/308/368, C458/558/658.
                      www.gzanling.com
