PF-707
  • allan
    RTFM!!
    • 5459
    PF-707
    Hi guys sorry for the bother.
    Need a part number for the PS40 centering sensor for a PF-707.
    This unit was installed as a second PF for a C1100 but now need to use it on another machine.
    Would that be a kit that needs to be ordered?
    Whatever
    • 22965
    Re: PF-707
    hmmm...
    I never had tandem PF707s. I'll be interested in the answer. =^..^=
    • Toxic
      • 696
      Re: PF-707
      I think this is what you search for...
      A50UM55100 (A50UM55111 new ) Compensating Sensor
      • tsbservice
        Field tech
        • 7933
        Re: PF-707
        Now that one alone, if it works, would deserve another rep power ☝
        • Toxic
          • 696
          Re: PF-707
          We will see
          And btw who gives/judge rep. power points,status... ?
          • Synthohol
            Certified Konica Expert
            • 5749
            Re: PF-707
            There is a star icon on the bottom left of every post.
            If you feel the member has give accurate or helpful info you can click on it and rate that member.
              • 22965
              Re: PF-707
              It looks like a sheriff's badge, lower right of the specific post. =^..^=
              • Toxic
                • 696
                Re: PF-707
                Found it,never pay attention before on that simbol.
                So Allan is that it?
                • allan
                  RTFM!!
                  • 5459
                  Re: PF-707
                  Thank you.
                  Hope that would be available to me here.
                  Will check and let you know.
                  Whatever
                  • Christian_W
                    Support Specialist
                    • Jan 2011
                    • 33
                    Re: PF-707
                    Hi Allan,
                    in my opinion, there is no PS40 in the PF-707.
                    The PF-707 is the Paper Feed Unit from C1100, C2070 and newer Series.
                    Both Series have a Sensor inside the print system.
                    Christian
                    • Toxic
                      • 696
                      Re: PF-707
                      Originally posted by Christian_W
                      Hi Allan,
                      Christian
                      • allan
                        RTFM!!
                        • 5459
                        Re: PF-707
                        Will take 3 to 4 weeks to get it here.
                        It comes with the PF but this one was never installed as a primary PF and the sensor assy since have been lost in transport...
                        My friend needs this machine installed at a customer without that the machine is a brick.
                        Error code C-5109 pops up if the sensor is not there.
                        Whatever
                        • Christian_W
                          Support Specialist
                          • Jan 2011
                          • 33
                          Re: PF-707
                          Sorry, you are right.
                          I found the partnumber in the parts catalog page 120 (acessory parts)
                          A5AWR73500 Deflection Sensor Assy
                          • reckless
                            • Feb 2017
                            • 188
                            Re: PF-707
                            I have PF-707m hooked up to C6100. I am getting same error code : Error code C-5109
                            I don't see the sensor inside my brand new PF-707m. Is it needed for C6100?
                            • reckless
                              • Feb 2017
                              • 188
                              Re: PF-707
                              [ATTACH=CONFIG]43988[/ATTACH]
                              It says only for C1100 series does anyone know if this is needed for C6100?
