I need to NVRAM reset tool bizhub C280
  • mhmds102466
    • Jul 2019
    • 74
    I have an engineer now and I want to calibrate the colors
    We don't know a password
    Service Mode
    I previously got a tool
    A145FW
    For the machine bizhubC224_C284
    Please help me to skip the password and try all the default words
    "9272 9272"
    And
    "12345678"
    And
    "00000000"
    No default word worked
    Emil : al_rasheed_mecca@hotmail.com
    thank you
  • darry1322
    • Oct 2010
    • 817
    Re: I need to NVRAM reset tool bizhub C280
    Don't forget to run the setup procedure after you reset the NVRAM or you'll get the "lines of shame" again.
    • mhmds102466
      • Jul 2019
      • 74
      Ok
      • mhmds102466
        • Jul 2019
        • 74
        Is there a way to skip the password
        Like opening the door from the front
        Because the method works with C284
        • mhmds102466
          • Jul 2019
          • 74
          If there is no way I want to get the file
          A0ED0Y0-F000-GQ7-D1 (00)
          • copier tech
            • 8142
            Service Mode
            A145FW
            "9272 9272"
            And
            "12345678"
            And
            "00000000"
            [ATTACH=CONFIG]43961[/ATTACH]
            thank you
            Here you go.
            https://mega.nz/#!gd8jCYwD!agQynNHkd...n7cDkIl6JhTFuY
            NVRam Tool Instructions.pdf
            • mhmds102466
              • Jul 2019
              • 74
              I've got "lines of shame" again.
              Help me Please....
              I followed all the instructions
              • mhmds102466
                • Jul 2019
                • 74
                I want any engineer
                How are you doing
                I want any engineer
                To donate and I will contact him via imo program or Skype
                Or Facebook Messenger
                Solves me the problem
                lines of shame
                I would be very grateful to you and to the forum
                • mhmds102466
                  • Jul 2019
                  • 74
                  I have no problem if I ask for money because I would be very grateful to him after fixing the problem
                  • copier tech
                    • 8142
                    Help me Please....
                    You must have missed a step.
                    Post a print sample.
                    • mhmds102466
                      • Jul 2019
                      • 74
                      • mhmds102466
                        • Jul 2019
                        • 74
                        When copying only
                        • copier tech
                          • 8142
                          When copying only
                          Follow the set up procedure to the letter.
                          • mhmds102466
                            • Jul 2019
                            • 74
                            [QUOTE = copier tech؛ 958261] اتبع إجراء الإعداد للحرف. [/ QUOTE]
                            I don't know what to do
                            [COLOR=rgba(0, 0, 0, 0.54)]
                            [/COLOR][COLOR=rgba(0, 0, 0, 0.54)]
                            [/COLOR]
                            • copier tech
                              • 8142
                              [ATTACH=CONFIG]43974[/ATTACH]
                              [/COLOR]
                              Follow this guide.
                              Bizhub C220 C280 C360 Installation Manual.pdf
