I need to NVRAM reset tool bizhub C280
  • mhmds102466
    • Jul 2019
    • 74
    #16
    Re: I need to NVRAM reset tool bizhub C280
    Follow this guide.
    [ATTACH]43975[/ATTACH]
    where do I start
    • mhmds102466
      • Jul 2019
      • 74
      #17
      Follow this guide.
      Enter the service Manuel and never steps and do not show where
      • copier tech
        • 8144
        #18
        Originally posted by mhmds102466
        where do I start
        I'd suggest page 1.....................
        • copier tech
          • 8144
          #19
          Press counter, check details stop,0,0,stop,0,1
          • mhmds102466
            • Jul 2019
            • 74
            #20
            • copier tech
              • 8144
              #21
              [ATTACH=CONFIG]43977[/ATTACH]
              [ATTACH=CONFIG]43978[/ATTACH]
              [ATTACH=CONFIG]43979[/ATTACH]
              [ATTACH=CONFIG]43980[/ATTACH]
              [ATTACH=CONFIG]43981[/ATTACH]
              This is not a C280.
              • mhmds102466
                • Jul 2019
                • 74
                #22
                This is not a C280.
                I have 2 machines c280 c284e I'm having the same fonts problem
                • mhmds102466
                  • Jul 2019
                  • 74
                  #23
                  I'm so sorry for noise
                  Possible to send a video and I apply the steps so that I can solve the problem because the machine is worthless without copying
                  I am very thankful to you
                  Please help me
                  Please
                  Thank you and I appreciate your effort You are a hardworking and wonderful person
                  • mhmds102466
                    • Jul 2019
                    • 74
                    #24
                    Please list all steps to resolve the problem
                    In the form of points in order
                    I will take steps to solve the problem
                    • copier tech
                      • 8144
                      #25
                      Follow the installation process for the C224e similar to the C280.
                      Bizhub C224e C284e C364e C454e C554e Installation.pdf
                      • mhmds102466
                        • Jul 2019
                        • 74
                        #26
                        Performed the steps of the attached book page number E-11
                        The problem is still there
                        • mhmds102466
                          • Jul 2019
                          • 74
                          #27
                          • mhmds102466
                            • Jul 2019
                            • 74
                            #28
                            [ATTACH]43984[/ATTACH]
                            You skipped this step
                            Adjust the gradient adjustment
                            Because
                            Tray 1 with A3 has a problem skipping A3
                            And I went to tray 2 A4
                            The rest of the steps are completed
                            The problem remains
                            • arahael
                              • Mar 2013
                              • 97
                              #29
                              remember
                              dont forget about
                              CALIBRATE TOUCHSCREEN
                              INPUT / CHECK TIME AND DATE
                              congratulations
                              • mhmds102466
                                • Jul 2019
                                • 74
                                #30
                                Originally posted by arahael
                                remember
                                dont forget about
                                congratulations
                                I carried out the steps as you told me and the problem was not solved, sorry
                                When shooting from the scanner above the glass blue appears in the entire page
                                When shooting from the federal apparatus over the glass appears red color in the entire page
                                I do not know what is missing step to complete the process to solve the problem Is there any meter or reading I have no data in the machine I photograph you possible know the solution
