Bizhub C552 - SMB version upgrade? firmware?
  • ECA
    • Dec 2014
    • 61
    Hi guys
    after pulling my hair out on setting up a SMB scan folder on our new domain (server 2019, and freenas).
    turns out the workgroup needs to be set as the domain name inorder for the bizhub to do the correct AD user auth.
    e.g
    SMB settings > Print settings > workgroup. set to XYZ (in caps). if for example the domain is xyz.local
    anyway, after endless "server connection failed" errors later.
    I realised the SMB the printer was using was version 1! FFS
    Is there any firmware updates to upgrade to v2 or v3?
    rom verison below
    Code:
    [TABLE="class: data-table-noline, width: 500"]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller BOOT Program
    [/TD]
    [TD="width: 240px"]A0P00Y0-1E00-G00-02(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller SubSet[/TD]
    [TD="width: 240px"]A0P00Y0-1F00-G00-12(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller[/TD]
    [TD="width: 240px"]A0P00Y0-0100-G00-C2(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Operation Panel Message Data[/TD]
    [TD="width: 240px"]A0P00Y0-8100-G00-C2-00[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Fax Board Controller1[/TD]
    [TD="width: 240px"]15LA-0040-G02-13-000(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Fax Board Controller2[/TD]
    [TD="width: 240px"][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Scanner[/TD]
    [TD="width: 240px"]A0P00Y0-0023-G00-82[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Printer[/TD]
    [TD="width: 240px"]A0P00Y0-0050-G00-15[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]ADF[/TD]
    [TD="width: 240px"]A0HT0Y0-0024-G00-04[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Finisher[/TD]
    [TD="width: 240px"]A0HR0Y0-0071-G01-05[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Panel CPU[/TD]
    [TD="width: 240px"]A0P00Y0-8900-G01-01[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]DSC1[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]DSC2[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Loadable Device Driver[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]SD[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Voice Data
    [/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Movie Data[/TD]
    [TD="width: 240px"]A0P00Y0-A000-G00-04[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]Dictionary Data[/TD]
    [TD="width: 240px"]A0ED0Y0-B000-G00-0000 [/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]OCR Library[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller System
    [/TD]
    [TD="width: 240px"]A0P00Y0-1000-G00-C2(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller Print Controller[/TD]
    [TD="width: 240px"]A0P00Y0-3000-G00-96[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller Print Controller Font[/TD]
    [TD="width: 240px"]A0P00Y0-3F00-G00-21[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller Print Controller Demo Page[/TD]
    [TD="width: 240px"]A0P00Y0-3E00-G00-01[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller MIO[/TD]
    [TD="width: 240px"]A0P00Y0-5000-G00-23(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller PSWC[/TD]
    [TD="width: 240px"]A0P00Y0-5100-G00-20(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller MIB IF[/TD]
    [TD="width: 240px"]A0P00Y0-5200-G00-10[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller IPP IF[/TD]
    [TD="width: 240px"]A0P00Y0-5300-G00-10[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller Outside Controller IF[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller TCP/Socket[/TD]
    [TD="width: 240px"]A0P00Y0-6300-G00-21(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller OPEN API[/TD]
    [TD="width: 240px"]A0P00Y0-7000-G00-13(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller Operation Panel[/TD]
    [TD="width: 240px"]A0P00Y0-8000-G00-C2(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller CSRC Control Body[/TD]
    [TD="width: 240px"]A0P00Y0-8300-G00-02(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, width: 260px"]MFP Controller PIC[/TD]
    [TD="width: 240px"]A0P00Y0-8200-G00-A0[/TD]
    [/TR]
    [/TABLE]
  • tsbservice
    Field tech
    • 7999
    Re: Bizhub C552 - SMB version upgrade? firmware?
    There is no FW that officially support SMBv2 or SMBv3 for this model.
    • ECA
      • Dec 2014
      • 61
      any workaround?
      • Synthohol
        Certified Konica Expert
        • 5808
        FTP is the workaround.
        • copier tech
          • 8133
          Originally posted by ECA
          any workaround?
          Scan to email, we use a gmail account as do many other owners of these old boxes.
          Or if the client must have SMB use a NAS drive.
