PF-707 Power error
  • dean0212
    • Nov 2019
    • 2
    PF-707 Power error
    Hello.
    I have a Konica Minolta C6100 which has an error with the PFU, seemingly out of the blue. "Please confirm power cord and breaker switch of PFU and turn on power again". Has anyone seen this before and know how to correct it or what caused it?
    Thanks.
    • 22937
    Re: PF-707 Power error
    Yeah, on a C1060 I tripped over the power cord while walking around the PFU and kicked out the power cord. Now it's got strain relief so that can't happen again. =^..^=
    • dean0212
      • Nov 2019
      • 2
      I wish it was that easy. It has the strain relief on it and the cord is secure. I've been troubleshooting C-4521, 4522, and 4523 Color registration sensor errors up til that point, when, on a restart, this came up and hasn't gone away.
      Thanks.
        • 22937
        Doesn't sound good ... like an MFPB. Hopefully it will solve multiple issues. =^..^=
        • CHIPOLEON
          • Nov 2023
          • 1
          Hello, has anyone found the solution to the power error, I have a km c-4065.
          had a power outage and the PFU is not starting, checked and swapped cables, the two breakers
          are engaged.
          thank you
          • wjurls
            • Feb 2017
            • 492
            When the power supply units in these accessories fail, it will display as though the A/C is unplugged. They are simple to test power supplies. If they have A/C coming in, they should have DC being output. There are no remote turn on signals to contend with like on the main body.
            Check your input and output voltages (see photo). Replace the offending power supply and you should be good.
            If you need a power supply, let me know. I have a few of them.
