color line probleme
  • Gael
    • Oct 2019
    • 18
    color line probleme
    Hello,
    I have color line problems when i print or copy (Copy.pdf. I have toner powder on my transfer unit.
    Can someone help me ?
    Im French and I am sorry for the quality of my english.
    Re: color line probleme
    Originally posted by Gael
    Hello,
    I have color line problems when i print or copy (see attachment). I have toner powder on my transfer unit.
    what attachment?
    • Gael
      • Oct 2019
      • 18
      you are too fast, i just fixed the attachment
      • tsbservice
        Field tech
        • 8053
        What model?
          Hello, I have color line problems when i print or copy ([ATTACH]44039[/ATTACH]. I have toner powder on my transfer unit. Can someone help me ? Im French and I am sorry for the quality of my english. G
          looks like a transfer belt cleaning issue.
          please post the page counts on:
          Drums/Dev/Belt/Fuser
          • tsbservice
            Field tech
            • 8053
            Agree, looks like belt cleaning blade if sample is SEF.
            • Gael
              • Oct 2019
              • 18
              What model?
              Konica C220
              • Gael
                • Oct 2019
                • 18
                I will do that and post back
                • Gael
                  • Oct 2019
                  • 18
                  What means SEF ?
                    What means SEF ?
                    short edge feed = SEF
                    long edge feed = LEF
                    • BaconSteve
                      • Apr 2019
                      • 140
                        • 23010
                        If I were to make a guess I'd say the spout that carries the primary transfer waste toner to the waste bottle is likely clogged. From there the primary transfer cleaning unit backs up until the waste toner oozes out at the seals.
                        Check to see that there is some room in the waste bottle to accept transfer waste toner. I had a bizhub 654e the other day that entirely filled the primary transfer waste area of the waste bottle without triggering the bottle full sensor. =^..^=
                        • Gael
                          • Oct 2019
                          • 18
                          So i Cleaned the transfert belt and the blade.
                          Now i have no thread but i dont know for how long.
                          Blackcat is right "the spout that carries the primary transfer waste toner to the waste bottle is likely clogged. From there the primary transfer cleaning unit backs up until the waste toner oozes out at the seals".
                          I disassembled and cleaned the spout and the tank. But this i not the first time i have the spout clogged.
                          We will see in the future if the problem is solved definitively.
                          My C220 tells me that the drum units have expired yesterday (coincidence) but i'm sure we can still use them. Is it possible to remove the alert that says to change the drum ?
                          Than you to everyone for your help regarding the thread problem.
                            • 23010
                            Once they show "Replace..." Flipping the soft switch for the consumables will only affect the next replacement. If it were me I would turn off the comsumable popup, but until you install new drums it will still display.
                            • Gael
                              • Oct 2019
                              • 18
                              If i understand correctly, Flipping the soft switch will not work if i do not change the drums ?
                              But if i flippe the soft switch and i change the drums, i'll never have a message again ?
