color line probleme
  • Synthohol
    Certified Konica Expert
    • 5824
    #16
    Re: color line probleme
    Yes. Disabling notifications only works when there are none currently displayed.
    Once the egg is cracked you are stuck making the omelet.
      Great analogy!
        • 23008
        #18
        Originally posted by Gael
        If i understand correctly, Flipping the soft switch will not work if i do not change the drums ?
        But if i flippe the soft switch and i change the drums, i'll never have a message again ?
        Correct. =^..^=
        • BaconSteve
          • Apr 2019
          • 140
          #19
          So... what if I like sunny side up?
          • Synthohol
            • 5824
            #20
            Salmonella?
            • Gael
              • Oct 2019
              • 18
              #21
              Thanks for your help. I bought chips for the drums and i will change them.
              Can you tell me if my settings are good for disabling notifications (see attachment) ?
              Do i need to do something else ?
              Can you tell me if my settings are good for notifications to stop appearing?
              • Gael
                • Oct 2019
                • 18
                #22
                nobody can help me ?
                • Synthohol
                  • 5824
                  #23
                  thats not the right screen to disable notifications.
                  • CompyTech
                    Super Tech
                    • Feb 2011
                    • 706
                    #24
                    You'll have to upgrade firmware possibly first. Then there are 2 software switches to enable. You also have to make sure the Stop Life is set to Not Stop. There is a tech bulletin on the KM site about it.
                    • Gael
                      • Oct 2019
                      • 18
                      #25
                      I will try to find the firmware and install it. Do you know where i can find the firmware ?
