What do KM machines have against NTP servers?
  • John Kaufmann
    • Sep 2013
    • 116
    [Misc] What do KM machines have against NTP servers?
    Some people have said that the bizhub error "Time adjustment was not successful" comes from an invalid NTP server, but EVERY server (including those used on our computers) gets the same response -- and also fails PING from the bizhub (but, again, not from others hosts). Even pool.ntp.org fails. I know the standard "fix" is to turn Off (the default setting) "Time Adjustment Setting" ... but why? It's there for a reason, right?
    [BTW: everything on the other side of NAT seems to fail the bizhub PING. That may be a clue, but I'm clueless about what to do with it.]
  • emujo2
    • Mar 2017
    • 1579
    Re: What do KM machines have against NTP servers?
    The fix is to point the Bizhub to an internal server. With so much browser security today, many machines are failing to get to the outside world..E
    • copier tech
      • 8202
      I use "time.windows.com" for my Bizhub time servers or if that fails or DNS is not resolving the name use an IP NTP instead (207.58.142.213) for example.
      Konica are the only MFP that will display an error if time is not resolved.
      • rrrohan
        • Sep 2011
        • 1977
        ive stopped setting auto adjustments for this very reason and either just manually set it or use NTP but sync it manually on PM calls
        the only customers in my experience that even notice time being wrong are those that still print faxes and need proof via TX report that a fax was sent before some deadline
        • Bix
          • Apr 2018
          • 1421
          In all these years I never managed to set one time to activate automatic time adjustment.
          This is really frustrating for those with faxes. The good news for Europe is that next year there will be no time zones anymore. It seems almost done on purpose
          • John Kaufmann
            • Sep 2013
            • 116
            Thanks! It took a little time to explore your answer (I'm still not finished with the several threads of it), but in short: the key is getting DNS set up properly.
            • rrrohan
              • Sep 2011
              • 1977
              I try to always point them to the domain controller via IP.
              server will generally never change its IP so its safe to use this instead of host name
              One thing i noticed is CSRC doesnt use the same clock as what you see when you print meter readings page or see in user mode on screen
              Ive had a few machines with correct time yet CSRC thinks its 2021
              • John Kaufmann
                • Sep 2013
                • 116
                Originally posted by rrrohan
                ... One thing i noticed is CSRC doesnt use the same clock as what you see when you print meter readings page or see in user mode on screen
                You mean NIST's CSRC? - I didn't know they had NTP service.
                • Synthohol
                  Certified Konica Expert
                  • 5892
                  I use nist.time.gov and make sure 8.8.8.8 in one of the DNS selections and make sure the copiers clock in both places is at least close first.
                  • John Kaufmann
                    • Sep 2013
                    • 116
                    Originally posted by Synthohol
                    I use nist.time.gov and make sure 8.8.8.8 in one of the DNS selections ...
                    Good point on Google DNS. Do you know if the server pool at nist.time.gov is preferable to the one at pool.ntp.org?
                    ... and make sure the copiers clock in both places is at least close first.
                    "both places"? I thought the copier had only one clock.
                    • John Kaufmann
                      • Sep 2013
                      • 116
                      • Synthohol
                        • 5892
                        depending on the series, in service mode you either hit stop 3 for the newer 8-9 series and stop 1 1 4 4 c on the 4 series and previous.
                        then in admin mode make sure the time and date are the same.
                        2 places
