Konica c6500 wrinkling paper
  • Rohullah
    • Sep 2019
    • 37
    Hi everyone
    I have a KM c6500 wrinkling paper inside fuser.
    It happens with 70gsm paper to 130gsm, 150gsm is better, 210 or more no problem. It happens in single side and double side.
    The wrinkling happen inside fuser, but dont know what is problem.
  • tsbservice
    Field tech
    • 8053
    Re: Konica c6500 wrinkling paper
    Fuser past life?
    • Rohullah
      • Sep 2019
      • 37
      Fuser past life?
      Its a second hand , now its 45k, but maybe they have reseted before
      • eccelobo
        • 113
        Clean the entrance plate, and check the state of the fusing lower roller. Good Luck!
        • Albonline
          • Sep 2008
          • 1153
          Also the bearings and heat sleeves. if its rattling around loose in there rebuilt it!
          • K-3
            service technician
            • Feb 2018
            • 51
            look at all the bearings and heat sleeves in the fuser unit also check the oneways and all gears. is the fuser belt or press roller look worn. in a pitch i have soaked the bearings in wd 40 till i could get new ones ordered
            • Toxic
              • 698
              Agreed for bearings and heat sleeves,have that recently.
              Try to manualy rotate fusing knob when rollers make pressure and observe does it equally moves left and right side of lower roller approaching to fusing belt
              • Rohullah
                • Sep 2019
                • 37
                Thank you guys from everyone of you
                My printer server hard drive damaged, waiting to receive new one. Than i will come back on this post.
