Hot o/p paper C3851 konica
  • hemai2005
    Professional Print
    • 108
    [Electrical] Hot o/p paper C3851 konica
    Hi guys,
    I have C3851 MFP, give paper very hot in copies and printing, I decreased the fusing temp to min degree but still same problem, does anyone have solution for that please.
    sigpic
    Learned a lot will become an expert
    Re: Hot o/p paper C3851 konica
    Originally posted by hemai2005
    Hi guys,
    what GSM of the paper?
    what are the tray settings for paper type?
    after changing fuser temp, are you getting quality problems? (poor bonding of toner)
    you have to realize most fusers run @ 230 C
    • hemai2005
      Professional Print
      • 108
      Plain paper, 80 gsm, letter size, no any problems in quality after decrease the temp. It's just decreased to - 10
      sigpic
        • 23010
        So what are you trying to fix? You must know that it's supposed to get hot to fuse the image. I'm very confused. =^..^=
        • copyman
          Owner / Technician
          • Sep 2005
          • 4765
          Those small kon/min run very hot. The 3100P get so hot the fuser cover turns brown and plastic gets nice and crispy.
          A few customers have complained and was thinking about turning down the temp or having it go into energy save mode faster, etc. Took a quick look on knowledge base and didn't see anything it.
            • 23010
            It will certainly extend the life of the fuser ... and the whole machine, to have is go into sleep mode quicker, and I encourage it. On Kyoceras they call it Silent Mode, and I think it should be the default. The screen is on and accepts commands, but the engine is fully asleep, and must do a complete warmup to print. But the funny thing is that the customers with these tabletop MFPs can't wait 30 seconds to get a print. It's just too long, even if it doubles the lifespan of the machine. =^..^=
            • tsbservice
              Field tech
              • 8053
              Read in your SM about Fan control, test and make sure all fans are working at designed speed and time, especially Paper cooling fan.
              Vacuuming blocked filters also may help. Check that Smart Fusing control is permited in Service mode. Last but not least - swap with another fuser unit if possible.
              Good luck
              BTW, nice RP(300) BC
              • hemai2005
                Professional Print
                • 108
                Good luck
                I did already yesterday load check for All fan specially Paper coolling fan, and all working fine , machine has 20k copies (New) , fusing nice & new but I'll try with another fuser swap if available.
                Thanks man.
                sigpic
