C308
  • deputydogg
    • Nov 2015
    • 172
    C308
    We just got a new in box C308 from ACM, it is giving a message of "Developing Unit Installation Error' and "Drum Unit Installation Error". I have checked every where for any missed packing tape, also talked to their tech support and have not been able to resolve this.
    Any suggest ?
    Thanks,
    Dave
  • tsbservice
    Field tech
    • 8053
    Re: C308
    Hi Dave, did you follow installation sheet instructions coming with the unit? Never heard about those error messages in the feeld.
    • deputydogg
      • Nov 2015
      • 172
      Re: C308
      I did. I've went back over them 3 times. On page E-6 step 13 says "remove the protective tape from the developing units"(which there was non) however there was a separate sheet of paper "additional information" which says "the protective tape shown is not attached, the removal procedure is unnecessary". I don't know what I could have missed.
      • copier tech
        • 8202
        Re: C308
        Any suggest ?
        Thanks,
        Dave
        Hi Dave,
        Has the machine been in a cold environment? seen random messages when a machine has been left in the van overnight etc.
        • deputydogg
          • Nov 2015
          • 172
          Re: C308
          Hi Dave,
          It was shipped to us via tractor trailer but has been in our office for about a week, which is climate controlled.
          • Flash
            • 378
            Re: C308
            Remove the waste toner box and remove the cover behind it. I think there are three screws holding it on. Reseat the connectors on the front side board. If you are getting an error on one of the color drums try swopping it with one of the other drums and see if the problem moves,
            • Synthohol
              Certified Konica Expert
              • 5892
              Re: C308
              there is packing material on top of the black drum during shipping?
              some little orange guitar pick looking thing.
              • deputydogg
                • Nov 2015
                • 172
                Re: C308
                No dice.
                • deputydogg
                  • Nov 2015
                  • 172
                  Re: C308
                  It was removed.
                  • allan
                    RTFM!!
                    • 5462
                    Re: C308
                    Faulty chip? Or Missing chip or connectors not plugged in on board.
                    Do a trouble reset for good measure.
                    Whatever
                    • tsbservice
                      Field tech
                      • 8053
                      Re: C308
                      Dave,
                      You may check also this:
                      "Drum Unit Detection Error" message after installing a new Extended Life Drum (DR315K).
                      CAUSE: Firmware prior to G00-V1 is installed on the MFP.
                      SOLUTION: Install firmware version G00-X4 or newer.
                      Another thought, check if drum units chips are there, if no/wrong chip I think it will throw that message.
                      As for Developing units TCR sensor is used for their detection...maybe somebody was trying to mess with chips?
                      • deputydogg
                        • Nov 2015
                        • 172
                        Re: C308
                        Dave,
                        On mykonicaminolta.com the lasts I see is G00-U8 ?
                        I updated it to that, still same problem.
                        • tsbservice
                          Field tech
                          • 8053
                          Re: C308
                          U8 is old one prior to V1 and next after. What about chips?
                          • deputydogg
                            • Nov 2015
                            • 172
                            Re: C308
                            Chips are all there. It is a brand new machine.
                            So G00-V1 is newer than G00-U8 ? The G00-V1 has a newer date listed beside it.
                            • Bix
                              • Apr 2018
                              • 1421
                              Re: C308
                              Hi, consider that the firmware update uses the alphabet order. Sometimes you might find a newer date in an old firmwae because KM simply modified the document.
                              Example:
                              G00-A0 | old firmware
                              G00-B0 | new firmware
                              There is a training course on this
