New driver install remains as "unspecified" in windows.
  • Schneider
    • Sep 2018
    • 25
    Hey all
    Ive been installing drivers for years with no issues for KM machines using the add printer wizard but in recent months I keep getting a few windows PC's holding the device as unspecified, you then cannot configure the driver etc.
    To make it more confusing the driver can be used normally in Word, Excel etc. I have gone back the next day and it attempted new installs and it works no problems?
    I suspect this is a windows issue but it is can not find any answers. I have latest drivers, latest firmware and even rebooted PC's but nothing seems to make a difference?
    Rather troublesome when you cant change defaults or add options.
    Any ideas, thanks in advance.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1869
    Re: New driver install remains as "unspecified" in windows.
    Darn you M$. Back to missing printer icons again on W10
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • rrrohan
      • Sep 2011
      • 1976
      you can still make changes but it wont work through Control Printers
      just do it through Word or something
      Just disable icon downloading in group policy
      • tsbservice
        Field tech
        • 7981
        Make them to upgrade their Windows version to the latest and greatest, seems that M$ repaired what they broke.
        • copier tech
          • 8131
          Originally posted by Schneider
          Hey all
          Windows will add ay printer on the network & install using WSD.
          I disable WSD on all new installs now for this very reason.
          • Qball
            • Jun 2013
            • 127
            This is the solution we show to our customers. We have their IT group implement it. I don't like fussing with anyone's registry. Also, adding a printer through print management is unaffected by this little glitch. Even if the printer shows unspecified in control panel, it's there and functional in print management
            • rrrohan
              • Sep 2011
              • 1976
              its strange because i replicated this in our workshop and i had to apply this group policy change and installed printer but have since re enabled the icons and now its working fine with proper icon
              • tmaged
                • Oct 2008
                • 1869
                Not strange at all. If you read the article, the server that it connects to get the icons was down. It's now back up at Microsoft. At this time, you shouldn't have to mess with a workaround.
                Hope that helps !
                -Tony
                www.dtios.com
