B958 leaving random marks on prints
  • rrrohan
    • Sep 2011
    • 1977
    see attached PDF's
    This is Halftone at 50
    Ive swapped parts with another 958 and the fault stays with this copier
    I did
    ITBU
    ITRU
    Fuser
    Drum
    Dev
    Would you say this is a power issue?
  • Synthohol
    Certified Konica Expert
    • 5804
    Re: B958 leaving random marks on prints
    can you print on A3/11x17 and does the blorb repeat?
    • rrrohan
      • Sep 2011
      • 1977
      i never tried on A4 but thats only because it defaulted to A3 and I didnt think the paper size would matter
      almost all the customers prints are A3 booklets
      Do you think its worth me going back to test on A4 and if so why.
      The blobs dont repeat, they change all the time.
      • elmaligno
        Expert technician KM
        • Oct 2009
        • 302
        Try to change fuser speed.
        Field technician since 1994
        • allan
          RTFM!!
          • 5462
          Does those areas feel gritty?
          Could be developer on the prints.
          In that case it could be a bad HV contact at the back?
          Whatever
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            This, and make sure loop sensor near transfer roller isnt broken.
              • 22999
              If it's fuser speed, the buckle is changing as the paper is passing the drum. A misaligned fuser can cause the paper to track to the front or rear causing the paper to pull away from the drum. A4 LEF is very short in the feed direction, and doesn't get much of an opportunity to track off center (you shouldn't see much of an effect on A4 LEF).
              A bad connection at the second transfer can cause a curved void all the way across the page. very similar to what you're seeing.
              Are you getting any jams or errors? =^..^=
                the A3 would show 'repetitive defects' in ALL image process units, A3 = 11x17 LGL
                A4 = 8.5x11 shorter media SEF LTR
                • rrrohan
                  • Sep 2011
                  • 1977
                  not gritty at all
                  nah no jams, no errors.
                  what do you mean by misaligned fuser? didnt think there was any adjustment, it just screws in.
                  yeah i went back and tried A4, and its perfectly ok on A4 portrait.
                    • 22999
                    There were some Kyoceras with fuser alignment issues, that produced a similar effect. Not bizhubs. Just speculating.
                    I'd try adjusting fuser speed. =^..^=
