Bizhub C250 , strange background in print and copy
  • GIUBOSS
    • 1436
    hello guys, both in print and in copy on the sheets leaves me this strange background, I made the gradation of the calibration settings and the color registration. Help would be appreciated. thanks
  • Techlife
    • Mar 2015
    • 27
    Re: Bizhub C250 , strange background in print and copy
    Sample??
    • GIUBOSS
      • 1436
      Originally posted by Techlife
      Sample??
      Ok thanks
      • tsbservice
        Field tech
        • 8020
        Problem on both Black and Color copies?
        Possible faulty Print Head Unit, as a test, the print heads can be swapped.
        • Toxic
          • 698
          Agreed with tbservice, most likely print head,have that situation long time ago.
          • GIUBOSS
            • 1436
            what do you mean by printhead? is a multifunction A3 color laser. Konica Minolta bizhub C250 old machine.
            • Synthohol
              Certified Konica Expert
              • 5849
              printhead=laser=write unit
              same thing
              • GIUBOSS
                • 1436
                a colleague who repairs Konica Minolta suggests that I revise the grids of perhaps oxidized photoconductor units. I'll start from here. Then I will think of the "printhead" unit.
                • eccelobo
                  • 113
                  Also check the harness between the Laser Unit and MFP Board, sometimes it's bad connection. Good Luck!
