Reset total counters c368
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    [Electrical] Reset total counters c368
    hi folks! does anyone know how to set the total counters to 0 in the c368 series??
    Field technician since 1994
  • copyman
    Owner / Technician
    • Sep 2005
    • 4666
    Re: Reset total counters c368
    Why do you want to do this? Do you know it is illegal to turn counters back?
    This is why Kon/Min makes it so hard to do. Only way it can be accomplished is by replacing several "expensive" boards, MFP, SSD, etc
    • Synthohol
      Certified Konica Expert
      • 5814
      put the SSD in a dry paper towel and microwave on low for no more than 8 seconds.
      that will do it.
      • allan
        RTFM!!
        • 5462
        that will do it.
        Was skeptical about doing that, what do you know it worked!
        Whatever
          that will do it.
          I've had to extend the time out to 20secs...
          • copyman
            Owner / Technician
            • Sep 2005
            • 4666
            that will do it.
            Shoot! I thought you said 8 mins
            • Synthohol
              • 5814
              Is your microwave over 5 years old?
              The nuclear rays are getting rusty. Have them cleaned by a professional or buy a new one.
              • Toxic
                • 697
                that will do it.
                I slightly improved this process.
                If you hold microwawe on for about 30 sec you will reset all consumables as well as total counter.
                • rrrohan
                  • Sep 2011
                  • 1977
                  i already have a few machine that do this. reports 0 prints in top right corner of consumables print out for some reason, sadly its still correct everywhere else
                  • tsbservice
                    Field tech
                    • 8003
                    This is known FW bug. Update FW.
                    • Copier repairman
                      • Aug 2019
                      • 86
                      The C368 model does not have an NV-RAM reset tool firmware.
                      But you can reset the total counter.
                      You can use Bizhub SSD copy tool.
                      • Copier repairman
                        • Aug 2019
                        • 86
                        [견적 = elmaligno; 사람들! 누구든지 c368 시리즈에서 총 카운터를 0으로 설정하십시오. [/ 견적]
                        How to make a "0" counter.
                        1. Replace with a new SSD.
                        2. Install after formatting the SSD.
                        3. Copy using SSD Copy Tool.
                        I bought a copy tool.
                        Contact canonrp@naver.com
                        Is satisfied.
                        • Synthohol
                          • 5814
                          this site needs moderators to delete these criminal posts.
                          • tsbservice
                            Field tech
                            • 8003
                            Absolutely agree!
                              I'm on board with this.
