Forward TX Eroro while sending A3 pages by email MS 365
  • samaco
    • Nov 2019
    • 4
    Dear all,
    We have Konica Menlota bizhub c224e. We used to scan documents size A4 to email office 365 but the number of pages is limited to 30 pages.
    I was trying to scan 12 A3 pages to my email, but it gives me the below error after 40 seconds. If pass when i scan less than 10 A3 pages.
    Please help me to find a solution for this annoying issues either for A4 & A3
  • qbert69
    • Mar 2013
    • 1152
    Re: Forward TX Eroro while sending A3 pages by email MS 365
    Originally posted by samaco
    Dear all,
    I have NEVER heard of a page amount limitation!!! I HAVE heard of a file size limitation based on the complete attachment file size--usually multi page PDF. You either need to set your resolution lower and/or change your scanning color space to black and white. I recommend 200 DPI, Fine Resolution, Black and white. Alternatively, you can contact your IT Administrator to increase the allowable file size attachment!!! Also to note, the Office 365 may have an overall disk quota limitation that you have exceeded, in which case you'll still need to contact your IT Administrator to get it resolved.
    Good Luck!!![emoji41][emoji1303]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • samaco
      • Nov 2019
      • 4
      thank you for your reply and sorry for the late response.
      As you said the limitation is on the PDF file size. The system admin says the limitation is 35 MB on each file.
      What is your recommendation?
      • Woxner
        • Jul 2011
        • 854
        35 mg for email server is pretty high. most are 15 megs. set to compac pdf and 200 dpi and b/w. you can also set the binary in email settings on the machine to 15. this will devide the email in too several emails if needed.
        • samaco
          • Nov 2019
          • 4
          Thank you again
          I am wondering if color scan make the size of the file bigger!!
          Second, I would like to know how to change the settings in the email to binary please.
          • Synthohol
            Certified Konica Expert
            • 5922
            scanning in color makes the file 4x the size.
            try compact PDF first. you wont see a difference in quality.
            if you scan to SMB you can email the attachment from your PC and it will ask to break it up in pieces and put back together at the recipient. usually.
            • qbert69
              • Mar 2013
              • 1152
              3x the size I believe as the scanner uses the RGB spectrum and not CMYK!!!...8 Bits per color so 24 bits total!!![emoji6][emoji1303]
              • Synthohol
                • 5922
                my bad
                • samaco
                  • Nov 2019
                  • 4
                  Thank you again and again for your helpful replies.
                  I have changed the settings on the scanner to grayscale PDF compressed and 200 dpi.
                  I will try it and see if it will send an email or not.
                  I am not able to attach screenshot here
                  • tsbservice
                    Field tech
                    • 8082
                    We must forgive You... cuz you're so cute
                    • allan
                      RTFM!!
                      • 5462
                      FTP or SMB will allow real big files if the quality is an issue.
                      Whatever
                      • allan
                        RTFM!!
                        • 5462
                        Eroro
                        ironic i would think.
                        Whatever
                        • emujo2
                          • Mar 2017
                          • 1579
                          Smarty Pants...lol
                          • tsbservice
                            Field tech
                            • 8082
                            Originally posted by emujo2
                            Smarty Pants...lol
                            Nope, just read some of his posts. He understands what's needed. Knowledgeable I would say at least.
                            I wouldn't judge the book by its cover(few emojis).
                            • qbert69
                              • Mar 2013
                              • 1152
                              Smarty Pants...lol
                              Go eat your Thanksgiving Turkey & take a Nice Looong Nap, Emujo2 Grumpy Pants!!![emoji23][emoji38][emoji1787]
