Artifacts on C364e on Screen Panel
  • cayyell
    • Feb 2013
    • 85
    [Electrical] Artifacts on C364e on Screen Panel
    Hi guys
    From a perspective of a PC, looks like a dead graphic card or corrupted graphic driver to me.
    And yeah, I did swap with a working screen panel and shows the same result.
    Is there a possible firmware to fix this?
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Artifacts on C364e on Screen Panel
    ok, if you boot to a firmware stick is the screen normal?
    • cayyell
      • Feb 2013
      • 85
      Nope, just done, still the same distortion.
      • rrrohan
        • Sep 2011
        • 1977
        id unplug the cable at MFPB and reconnect as you have obviously already done it at the touch panel end when swapping panel
        • cayyell
          • Feb 2013
          • 85
          Nope, tried that didn't work as well
          • rrrohan
            • Sep 2011
            • 1977
            does it still print ok?
            • cayyell
              • Feb 2013
              • 85
              I am guessing the mfp is dead.
              I forgot check that before I accidentally plug-in a NVRAM reset usb.
              So the print looks like this now
              both counter and test print. I am not sure because is this the pattern of uninitialized of the machine or what as I dont remember the counter list will look like even tho is uninitialized. But the gradient print is fine and smooth.
              • rrrohan
                • Sep 2011
                • 1977
                might be lucky and it just be a problem with RAM but id say MFPB
