Konica Minolta C454e Paper Jamming
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica Minolta C454e Paper Jamming
    Getting Paper jam in C454e With Error Code 30-03 in email and 11 on the machine.
    Please find the pics and advise.
    Thanks and Regards,
  • tsbservice
    Field tech
    • 7926
    Re: Konica Minolta C454e Paper Jamming
    What was done, from which tray, etc. Try to provide more information than average enduser. I'm sure you can do more.
    • mearmi
      • Oct 2010
      • 346
      machine was working fine . My tech printed 200 books staple folder.
      got one client to buy this printer. Bad luck my technician blowered And fully cleaned the printer since it is not working.
      as mentioned earlier it was working 100% perfect
      Please advise there something happened when he blowered and serviced
      i have to deliver the printer tomorrow please help
      thanks a lot
      • mearmi
        • Oct 2010
        • 346
        from all tray same thing is happening
        even the paper get wrapped on registration roller
        did u see the photos
        thanks please help
        • tsbservice
          Field tech
          • 7926
          Have him check reg sensor, is it free moving? Arm and spring on place?
          • tsbservice
            Field tech
            • 7926
            Also if paper makes it past fuser and jam between exit roller and fusing roller it may worth to check paper exit clutch harness or replace clutch: CL8 (p/n A161M20400)
            • copyman
              Owner / Technician
              • Sep 2005
              • 4545
              Good advice. There is a bulletin addressing 30-03 for CL-8 being bad or dirty. Not sure but thought the 30-03 code was when only using tray 3 LCC?
              • tech51
                • 846
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4545
                  I added the bulletin addressing 30-03 jam in previous post. Didn't want you to miss it if you read it already.
                    • 22952
                    J30-03 jams are usually caused by CL8 and/or the exit sensor (in one case both). But I would definitely install a second transfer roller. You'll want one of those. =^..^=
