C1085 duplex registration issue after 15 sheets
  • dagoof
    Still learning...
    • 220
    Got a strange one on a c1085 - the image is slipping out of registration predominantly on the trailing edge (both sides) when duplexing. It happens almost bang on after 15 sheets give or take, never an issue with the first dozen or so. If I run batches of 15 sheets it's fine, with only a few seconds in between batches.
    It doesn't happen when running simplex. Sporadically the issue doesn't happen at all (perhaps when the machine's been running for several hours).
    Anyone got any thoughts? Spoke to some who said they didn't think the registration roller would be a factor but I'm not sure
  • dagoof
    Still learning...
    • 220
    Re: C1085 duplex registration issue after 15 sheets
    Anyone care to throw their hat in on this? Still got me stumped!
    • Toxic
      • 697
      Are you tech or end user?
      Did you try something before to solve that problem?
      • tsbservice
        Field tech
        • 7977
        Of course he is a tech with that nice little badge Still learning...
        Imho every reliable tech should anchor on that motto.
        @dagoof, will upload some docs in few minutes, check your PM.
        Please, bear in mind I'm not a production guy, so articles may be somewhat or completely irrelevant.
        • methogod
          • Dec 2008
          • 917
          what's the meter?
          stock?
          which way is it shifting?
          • dagoof
            Still learning...
            • 220
            Big thanks to Tsb
            Methogod - The machine's got a fairly high meter (6m). This was using a 300gsm silk stock.
            The CMYK was slipping out of registration horizontally in the direction of travel (leading to trailing), I'll try getting a couple of pics.
            • methogod
              • Dec 2008
              • 917
              would think registration assy, at 6m. was it replaced at all?
              • dagoof
                Still learning...
                • 220
                Hi Methogod, we replaced the whole reg assembly but it's not really helped (it now pulls the reg back after slippage but will continue to fall out of registration on a cycle of 10-15 sheets).
                What would you suggest next?
                • BOTOY
                  • May 2016
                  • 46
                  Hi,
                  I think this is no a mechanical issue. Can you reset the machine in factory setting, then make un new print/side setting?
                  Could you take some picture?
                  • Synthohol
                    Certified Konica Expert
                    • 5804
                    does it behave if regular 75-80 gm2 paper is used?
                    does the tray being used matter?
                    have you tried the paper through the bypass (if installed or accessible)
                    jig the door interlocks and watch the edge of the paper as it passes and look for drift.
                    if drifting check for even tension on every hard roller(s) in the paper path.
                      • 22999
                      Originally posted by dagoof
                      Big thanks to Tsb
                      This is the maximum media weight AND glossy. I would be very surprised if it didn't have color registration issues. If you drop the gsm to 280 the problem will disappear. =^..^=
                      • dagoof
                        Still learning...
                        • 220
                        Thanks all for the replies
                        Blackcat - tried 280gsm silk, it's the same. 225gsm doesn't seem to be effected. However, it worked ok previously with the 300gsm stocks.
                        Synthol - have tried a 225gsm gloss and it works ok. Tray doesn't seem to matter (tried 2 & 3 from PFU, no bypass).
                        There is almost never a reg issue running simplex, so I'm pretty sure there's no major drift from PFU, this seems to be primarily limited to duplexing.
                        It tends to effect the mid-to-bottom of the sheet (trailing edge rather than leading edge).
                        Botoy - Yes, I'll get pictures. Is there anything specific I could try resetting before a reset on the whole machine?
                        • dagoof
                          Still learning...
                          • 220
                          Could anyone suggest anything? I'm guessing it's a mechanical issue in the ADU (i.e. rubbers worn)?
                          • Toxic
                            • 697
                            You said 225gsm is ok,no problem?
                            Did you try to trick machine and set up 225gsm and acctually put 300gsm into the tray and check does it have same problem.
                            • dagoof
                              Still learning...
                              • 220
                              Hi toxic, I tried cheating it at 225 setting but got the same result: first 12-15 sheets ok, then 7 bad before it self corrects, then 7 good, 7 bad etc on loop (give or take).
