C364e & C224e Electric Shock Sound at left hand side
  • denvertan
    • May 2019
    • 82
    I have few of this copier having "Bizzzzz...." sound at specific internal at the right of machine.
    The "Bizzz..." sound is clearly audible in some of the copier.
    Any idea how can I fix it ?
    Re: C364e & C224e Electric Shock Sound at left hand side
    sure it wasn't a BUZZZ or Zizzzzzt?
    you really expect us to help with that GRAND accounting of your problem?
    have you compared the sound to the timing chart in the SM?
    did you pull covers in that area to better define the issue?
    post a video of sound
    what are page counts on the supplies/parts?
    what have you done to try and isolate the problem?
    as much as you post here, you should be well aware of the prerequisites to requiring help.
    • mo0651
      • 1054
      They are BIZZZhubs. LOL sounds like a power supply cooling fan may have popped loose.
      • Bix
        • Apr 2018
        • 1421
        Hi, it depends on what kind of noise you hear. A video could help
        I have had several C364e with a hum coming from the power supply. If instead it comes from the fuser, you could try to adjust the Warp Up in the Service Mode (from Mode 1 to Mode 2, from mode 2 to mode 3 etc.)
        • DigiMan
          • Jan 2013
          • 262
          Damn you beat me to it!
          I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
          • tsbservice
            Field tech
            • 7910
            Me too!
            • JR2ALTA
              • Feb 2010
              • 2028
              Known issue on many bizhubs. I'm not a current KM tech but it was a capacitor on the power supply I think. It would buzz every 30 seconds or so. Sounded like a bug zapper. I think there was a update or bulletin in sure someone here can help.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4521
                Normal noise from power supply. Well not really normal but for Kon/Min it is.
                Wanted to add that I believe the noise happens when the fuser lamps / inductherm sys turns on and off. When sitting idle it happens periodically turning fuser on / off.
                If on the 554 and higher the squealing noise from fuser drive drowns it out so don't hear the customer complain as much. I had an electrical contracter almost sue me over a C220 buzzing to a point it was also buzzing at the circuit breaker. Once I saw that I had no choice but to take back machine and refund money. That wasn't normal. Would of sucked if a Biz C220 burned down a brand new building!
                • allan
                  RTFM!!
                  • 5459
                  Its the TRIAC controlling the lamp current.
                  The white silicone blobs on the power supply capacitors and coils help to keep them from vibrating to much.
                  Really eerie noise, customers complain about it.
                  Whatever
                  • denvertan
                    • May 2019
                    • 82
                    Current meter is @
                    552,251 for total black
                    382,843 for total colour
                    The sound happen in 5 second internal.
                    The sound is clearer when am nearer to this area of this board.
                      • 14350
                      There is a bulletin concerning this issue.
                      Problem
                      Abnormal faint buzzing/crackling noise.
                      Solution
                      CAUSE: Transformer on the DCPS.
                      SOLUTION: Perform the following setting in Service Mode.
                      1. Enter Service Mode.
                      2. Select Machine.
                      3. Select Heater Control Level.
                      4. Set from Level 1 to Level 4.
                      5. Power machine OFF/ON.
                      I have tried this "fix" on several machines. It has actually solved the problem a couple times.
                      • denvertan
                        • May 2019
                        • 82
                        Problem
                        Solution
                        2. Select Machine.
                        Do you have the bulletin to shaee wirh me ?
                        • copiertec
                          • Jan 2016
                          • 2184
                          Copier Addict just offered you a solution to your problem! Now you ask him for the TSB? How about thanking him and trying what he has suggested! ... After all it was just Thanksgiving here in the USA.
                            • 14350
                            That is the bulletin, I just copied and pasted it here.
                            • Copier repairman
                              • Aug 2019
                              • 86
                              Problem
                              Solution
                              2. Select Machine.
                              If you switch to Level 4, you will hear less or no sound.
