Language and Diplay problems
  • pabegsv
    • May 2017
    • 7
    [Misc] Language and Diplay problems
    Hi, i update the firmware of a Konica c224e, after the upgrade i had two issues:
    1-Spanish language option disappeared from the menu
    2-on the main screen a pink box appears covering the options
    What can I do to solve the problem?
    I suspect it is the firmware version, although it is supposed to be for those models
    Thanks for your help
  • emujo2
    • Mar 2017
    • 1579
    Re: Language and Diplay problems
    what is the exact file name of the firmware?? and did you check your county code in service mode to ensure this hadn't changed? I would expect if you did all system init back to factory then the country code would change as well. E
    • copier tech
      • 8174
      When you update the firmware you get the option to set the default language & machine type for your country.
      See attached from the CE manual.
      Laungauge Select.pdf
      • Bix
        • Apr 2018
        • 1421
        Be sure to download the Multi Language version.
        • emujo2
          • Mar 2017
          • 1579
          I missed the "pink box covering the options" can you post a image of this? E
          • pabegsv
            • May 2017
            • 7
            Sorry for the delay.
            The firmware file is A5C10Y0-F000-GDK-M1, I made a mistake in the newsletter attached to the firmware that does not include Spanish language.
            Now I have to get the right file, I don't know if it's possible you can help me.
            thanks
            Pd. About the image in attach that in a minute
            • pabegsv
              • May 2017
              • 7
              There are some pictures about the issues
              I'm sorry for my ignorance but I'm just starting to work with minolta copiers
              My English is not good either,
              thanks for your help
              • Synthohol
                Certified Konica Expert
                • 5847
                why GDK firmware? thats not normal.
                if you dont have a finisher tri-fold issue (what that special FW is for) then load the regular G20-m1 firmware.
                • Choclit007
                  • Oct 2010
                  • 58
                  The GDK fw was pulled from the KM's site - I had the pink line too so that was probably the reason.
                  GHV-M1 should be the minimum fw installed on that model per Bulletin 11472 (possible data loss issues).
                  You have to follow the specified procedure though
                  • pabegsv
                    • May 2017
                    • 7
                    Thanks for responding, I would like to know if someone can send me the correct firmware.
                    I don't know what data you need from the machine?
                    • Synthohol
                      • 5847
                      Pm sent
                      • elmaligno
                        Expert technician KM
                        • Oct 2009
                        • 302
                        Hola amigo, enviame un mensaje privado y te hago llegar el firmware. Ademas debes poner el SW 25 en 60 para que te acepte la ultima version del firmware
                        Field technician since 1994
                          • 14812
                          You are inviting the wrath of Phil b by typing in a non English language. Lol
                          • tsbservice
                            Field tech
                            • 8020
                            Do you have anything on topic?
                              • 14812
                              Nope! You?
