jamming
  • Billvo
    • 4
    [Jamming] jamming
    Hi All,
    Have a C754 that had a couple of jams from bypass using Thick 1 paper - now machine still says paper jam, (& code 11) but no paper to be found. Cleaned rollers and blew out some accumulated paper dust, but no go. Any thoughts? Thanks
  • Synthohol
    Certified Konica Expert
    • 5894
    Re: jamming
    take out the clear&gray paper dust remover from the sync roller in the door and REALLY clean it well.
    double check the OHP detecting sensor, can be dusty.
    paper dust tricks it into thinking there is paper there.
    • escalante
      • Sep 2018
      • 115
      Re: jamming
      Enviado desde mi SM-J701M mediante Tapatalk
      • Billvo
        • 4
        Re: jamming
        On the c754, where is the OHP detecting sensor?
          • 23010
          Re: jamming
          It's the one behind the paper dust collector. You may find that it's necessary to clean the three sensors in that area. You separate the 2nd transfer assembly from the door to see the three sensors. It gets very very dusting in that area. =^..^=
          • Synthohol
            • 5894
            Re: jamming
            there is a pic of it above your post
