Konica Minolta BizHub C458 - Account track / verify issues
  • ThatguyinAK
    • Dec 2019
    • 9
    Hello,
    New to these forums, not a "tech" but know enough be dangerous...
    I've got a Konica Minolta BizHub C458 that used to have account tracking on it - had to disable that for a time and am now "turning it back on".
    Previously, the account track worked where you would go to print from a program, would bring up the "preferences", you would have to choose the "basic" tab, then click the "account verify / account track" button, which would bring up another window where the user would type in their password, click verify, and then go on printing. The user only had to do this ONCE per day generally. This is where my issue lies - I can't figure out how to allow the user to only have to verify ONCE. Now, users have to verify for EACH print job.
    Can anyone please help!?
    Thanks in advance!
  • emujo2
    • Mar 2017
    • 1579
    Re: Konica Minolta BizHub C458 - Account track / verify issues
    Printer properties/settings tab/User Authentication Settings/ Verify authentication before printing. If checked it will check every time. E
    • ThatguyinAK
      • Dec 2019
      • 9
      So in the Authentication settings under printer properties, NOTHING is checked...should the "verify authentication settings before printing" be checked? I thought it would be checked/turned on, but it's not...
      • allan
        RTFM!!
        • 5462
        Jip but will ask you to enter authentication info every time you print.
        Whatever
        • ThatguyinAK
          • Dec 2019
          • 9
          Hmm...
          Trying to only get ONE authentication per day/user though...
          • Synthohol
            Certified Konica Expert
            • 5846
            then lock it in under Advanced-Printing defaults and apply.
            will not ask at all but any print under that ID will be "billed"
              • 23009
              If each PC has a dedicated user, why not just enter the password right into the driver defaults so it never asks? Whomever uses that PC gets billed.
              • ThatguyinAK
                • Dec 2019
                • 9
                Just about every PC has a dedicated user...how do I go about doing that?
                And by "billed" I assume you mean it counts the print for account tracking.
                I've been changing these settings via "pagescope web connection" not sure if that makes a huge difference or not.
                  • 23009
                  Sorry, I don't know the exact keystrokes off the top of my head. I don't get to do it often enough. Ok, I'll try:
                  On each PC: Start > search "Devices and Printers" > select print driver > Print Queue > Printer > Properties > Preferences > Basic > Authentication/Account Track > ... I think you can figure it out from here.
                  • rrrohan
                    • Sep 2011
                    • 1977
                    are you sure popup authentication dialogue when printing isnt ticked
                    never mind i re read everything and see you have already looked
                    • ThatguyinAK
                      • Dec 2019
                      • 9
                      Yes, this is how I've had people verify for printing - the issue is they have to do it EVERY time they want to print - I'm looking for a way for them to do it once per logon/day/whatever per user. Printer Issue.jpg
                      If you look at the screen shot - it kind of illustrates it. I want users to only have to enter that password once. I KNOW this is possible, because that's how it was set up before I turned off the account track setting.
                      Super frustrating. I feel like i don't have enough knowledge to properly illustrate my problem...probably why I'm not IT. lol, ugh.
                      • ThatguyinAK
                        • Dec 2019
                        • 9
                        Originally posted by rrrohan
                        [ATTACH=CONFIG]44340[/ATTACH]
                        Yeah, all of those options are left "unchecked"/"not marked".
                        • rrrohan
                          • Sep 2011
                          • 1977
                          what driver are you running?
                          not the universal driver?
                          what pc enviroment is it, terminal server or anything?
                          are the drivers local installs or from the server
                          • ThatguyinAK
                            • Dec 2019
                            • 9
                            So those are all questions I was nervous about as I'm not exactly sure on the answers...
                            I don't know what the universal driver is. >.<
                            Driver name: KONICA MINOLTA C658SeriesPCL
                            Driver Type: Type 3 - User Mode
                            Driver version: 10.1.1.0
                            That's what I've got on the windows printer test page I did. Then there's a number of additional print driver files listed, about 20 of them.
                            As far as environment, I've no idea. Sorry I'm not much help, this is probably my issue to begin with! lol.
                              • 23009
                              I'm guessing that these drivers are on a server somewhere and endusers settings are not saved at log-off. That's one step past my experience/expertise. One of the IT guys will have to take it from here. =^..^=
