C8000 C-0117 & J1608/J1610
  • wjurls
    • Feb 2017
    • 492
    Re: C8000 C-0117 & J1608/J1610
    [QUOTE=sendpiks;1651786]
    Originally posted by wjurls
    Choklit007, What was the definite solution that fixed this for you?
    In my case error go away only after I replaced ALL clutches used in vertical conveyance (6 clutches)
    Interesting. Perhaps an internal short in one of the clutches bringing the system down? None of my clutches are very old but I'll give it a try.
    This problem did start out with a blown ICP on the control board.
    I went through both vertical and horizontal units and cleaned all bushings and shafts.
    Thanks!!
    Lee
    • wjurls
      • Feb 2017
      • 492
      Just to follow up on my issue. Replaced all 6 clutches and the machine ran great. The question is why? Why would the clutches cause a C-0117 from tray 6, a J-1608 from tray 4, and a J-1610 from tray 5? The clutches I replaced weren't even very old. This one really baffles logic. Of the 6 clutches, only 2 are ever used depending on which tray is being fed from.
      • tsbservice
        Field tech
        • 7945
        [QUOTE=wjurls;1651931]
        Thanks!!
        Lee
        Blown ICP may trick machine logic. I mean if you just resolder it not replace whole board.
        • allan
          RTFM!!
          • 5463
          #19
          What was the issue with the ICP. Why did it go? ICP number?
          Whatever
          • wjurls
            • Feb 2017
            • 492
            #20
            [QUOTE=tsbservice;1654326]
            That's definitely plausible, but after I repaired the board and still had the error, I ordered a new one from Hytec. Same result. Bizarre!
            • wjurls
              • Feb 2017
              • 492
              #21
              Didn't see which ICP # "old eyes" but customer had called regarding the C-0117 codes. By the time I arrived, the machine didn't even recognize that the PF-704 was attached anymore.
              Replaced the offending ICP and the machine now saw the PFU, but the code persisted.
              • allan
                RTFM!!
                • 5463
                #22
                So all is good?
                Whatever
                • wjurls
                  • Feb 2017
                  • 492
                  #23
                  So all is good?
                  Yes, Thanks. Clutches fixed it.
