SD-511 Finisher on C224e
  • refillman
    • Nov 2019
    • 27
    Hi
    Printer C224e
    Finisher SD-511
    Fault Not Folding
    i was printing a normal job 24 page A5 booklet when half way though the job i had a jam in the finisher, i cleared all the paper out but now it wont fold the stapled booklet (keeps jamming) I've tried to print a single sheet and that goes through the finisher ok but ask it to fold and the sheet stays in SD4 position. it looks like it cant fold, can this be fixed.
    Regards
    D
  • GIUBOSS
    • 1437
    Re: SD-511 Finisher on C224e
    check the transport sections, the pressure springs and that there are no bits of paper in the corners or cracks. Surely you caused something when removing the paper. Do a job with the finisher's door open by inserting folded paper several times into the switches to follow all the steps of the paper. Are you a technician?
    • refillman
      • Nov 2019
      • 27
      not a
      technician
      the jam was caused by a booklet already saddle stitch and was about to be folded, Ive taken the sided off the finisher unit and tricked the switch, the motors and belts seem to work and spin ok it slots the booklet into position and when it comes to fold you hear the motor go but nothing happens.
      • refillman
        • Nov 2019
        • 27
        ran a single sheet through and asked it to be folded, the sheet is dropped in to postion and when the knife / fold bar comes down it seems to stutter and does not complete the movement, I know that there is no paper jammed in has all the booklets have come out in 1 piece and ive been over it with a touch a few times, please see pic below for the stuttering gear
        • refillman
          • Nov 2019
          • 27
          Re: SD-511 Finisher on C224e Error C1196
          just come up with error C1196 and has now disabled the Half / bi fold
          • GIUBOSS
            • 1437
            try to exchange the same engines of the section affected by the fault. Maybe you forced the engine .
            • refillman
              • Nov 2019
              • 27
              ive taken the motor off and it feels very tight and stutter to turn by hand not sure if its meant to smooth.
              I do think its the motor that has gone but where can I get one done a search on google and no results
              reagds
              D
              • GIUBOSS
                • 1437
                have you done a test by installing it instead of another surely working?
                • refillman
                  • Nov 2019
                  • 27
                  sorry i cant i only have one motor that size so i can test it against anything
                  the motor has a number SP-55rd-100
                  • GIUBOSS
                    • 1437
                    I have now seen it has only one of that type, if you lubricate the section on the steel axles and the engine can start again for a while and so you make sure that it is him. It should however be replaced
                    • refillman
                      • Nov 2019
                      • 27
                      i agree but i cant find a supplier for the part
                      • occus
                        • 339
                        Check for brocken wire of the exit grip solenoid. (The up- and downward moving assy). It grips the paper und pull it down. I had several brocken wires.
                        • refillman
                          • Nov 2019
                          • 27
                          been in SM and i can try to do a check on motors and solenoids but the C1196 error is stopping the check
                          • refillman
                            • Nov 2019
                            • 27
                            found out the reason the finisher was jamming and not folding the folding had snapped
                            • GIUBOSS
                              • 1437
                              Don't you have another finisher to test the engine on? Tell us how you solved it
