Bizhub C203 ADF image shift
  • Gina82
    • Oct 2017
    • 98
    I have a bizhub C203 that gives me an image shift (shown in attachment) whenever I place the original in the ADF, if I use the glass the issue never occurs. I have performed an auto stop position adjustment. Any ideas??
  • Synthohol
    Certified Konica Expert
    • 5822
    Re: Bizhub C203 ADF image shift
    slipping one way clutch(s) or rollers or dirty sensor that tricks the print to scan later than it should have.
    run the adf paper passage for 100 pages then test again. sounds like the original is just being delivered after the scan has started.
    how does it do on 2 sided?
      • 14701
      Is this scanned LEF or SEF?
      • allan
        RTFM!!
        • 5462
        That is way out. Supersized it just not give a timing jam. Agree with Synthohol that its probably a slipping or sensor issue.
        For interest sake give it an A3 or Leger size and see if it jams up on you.
        Whatever
        • tsbservice
          Field tech
          • 8007
          Your DF is not adjusted. Do it from scratch as a new one out of a box as per docs.
          Then come back and we will talk.
          • Gina82
            • Oct 2017
            • 98
            The original went SEF through the copier
            • Gina82
              • Oct 2017
              • 98
              I don't have any A3 paper, and would you give the same answer if I told you that the original was place in short edge feed when placed in the ADF?
                • 14701
                I would do the DF setup from start, but the minimum you need to do is "original tray width" adjustment and "Mixed original size adjustment"
                • allan
                  RTFM!!
                  • 5462
                  No the answer would have been more like the one from copier addict.
                  Small details help.
                  Whatever
                  • tsbservice
                    Field tech
                    • 8007
                    He refused to sticks to the basics so what's the point to double it?
                    • Synthohol
                      • 5822
                      i just saw that scan is sent short edge first.
                      i think the original width tray guides may be out of adjustment like start with the min/max adjustment?
                        nuff said....
                        South Park Beat A Dead Horse GIF - Find & Share on GIPHY
                        • Gina82
                          • Oct 2017
                          • 98
                          I haven't been even been on to reply to a lot of the comments. Just like I assume you all are,I get busy throughout the day.I will take his advice and perform the adjustments. Before I left the customer's office yesterday,I performed original tray width and the auto stop position adjustment. I wouldn't ask for help and not take the advice.
                            the outcome of that?
                            • Gina82
                              • Oct 2017
                              • 98
                              The outcome of the two adjustments done prior to the forum post didn't fix my issue. I'll go today and try the other installation adjustments.
