BH-C-360, no function.
+ More Options
Posts
  • Hansoon
    • Sep 2007
    • 3372
    BH-C-360 boots up normally without showing any errors. However the machine cannot copy nor print but it will scan into the network according tho the users. When trying to make a print, internal print or copy the orange activity indicator on the front will come on and it stays like that. No further action is executed.
    Not having yet the firmware with me I disconnected the hard drive and also the Fax-Card. I reseated the NV-Ram, but nothing helps right now. Will go there Monday morning and will install the firmware anew. Any other ideas please?
    I have a scrapper C-360 from which I could take the MFPB as a last solution. In case I would need to replace that board, are there any do's or don'ts when replacing a MFPB board?
    Hans
  • MVPunisher
    • 209
    Re: BH-C-360, no function.
    I am sure you already checked this, but it sounds similar to when the consumables are set to "stop" rather than no stop...
    • tsbservice
      Field tech
      • 7966
      +1 on this Hans. Print life counter list, replace what machine asking for if you want. Update FW accordingly if needed to non- stop at consumables end of life.
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        If the above suggestions aren't the issue and you need to replace the MFPB, there is no special procedure on replacing the MFPB like there is on newer machines which is what I loved so much about the older stuff. You could just grab a board from a scrap machine and put it in the one you were working on, put latest F/W on and everything would be fine. Unfortunately, the C360 series was the last that you could do that with (and of course the larger segment of the same era).
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • Woxner
          • Jul 2011
          • 838
          reset or replace transfer belt and fuser. even though there is no message it will stop coping and printing
          • mearmi
            • Oct 2010
            • 346
            Hans
            Had this issue. Reset Transfer Belt and Fuser life.
            • Hansoon
              • Sep 2007
              • 3372
              Problem solved by installing new chips for the CYM drum units. Though all the indicator bars where not completely eaten up and one segment was still present the machine did not show strangely enough in the display the information that those drum units would need replacement. Only the little oil can showed up but I had never a machine stopping operation for this reason until a clear message in the upper part of the display was requesting for new drum units.
              Thanks guys.
              Hans
              • femaster
                • May 2011
                • 1478
                It sounds like someone only did half the Long Life settings. The Long Life switch settings were done, which is why the meters never reached the end, but the copier was still set to STOP when any of the units reached their end of life count. If you were to change the setting to not stop, you wouldn't have needed to replace the chips. Just info for future reference.
                • tsbservice
                  Field tech
                  • 7966
                  Although the case is solved that does make sense. Good point.
                  • dannu
                    • Jun 2016
                    • 25
                    Hans
                    Fuser and Belt life end. Reset counter in service menu.
