FS 531 WITH C3070L
  • Shinigami
    • Mar 2017
    • 44
    FS 531 WITH C3070L
    Hello everybody
    I have a problem with an FS 531 WITH THE C3070L
    he does't connect
    but when I installe it with c3080 it works,
    • 23007
    Re: FS 531 WITH C3070L
    According to the brochure the C3070 should accept either the FS-531 or the FS-532. Perhaps a firmware update might help it connect? Or perhaps it requires a very specific combination of accessories? =^..^=
    • Synthohol
      Certified Konica Expert
      • 5823
      is the jumper wire on or off?
      check every step in the manual provided.
      • methogod
        • Dec 2008
        • 921
        jumper in to update firmware
        make sure you enter serial number or sometimes it wont see it.
        • Rolandito
          • Aug 2007
          • 90
          C3070L is not a production machine, its a Entry level machine, its different than C3070 without L, its the same engine, but firmware inside its different, So, some finishers are not compatible
          Konica's marketing stuff
