Bizhub "4" series tip
  • dave w
    • Jun 2015
    • 230
    Re: Bizhub "4" series tip
    Lights
    I use a USB led light - No need for batteries as most MFPs have a usb port and I also have a battery bank (pocket size) for when the machine has no power.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      Oh yea even with light I need reading glasses. I fought it for years until my arms wern't long enough anymore. Starting using them around 15 yrs ago and made a big difference. Doesn't matter how much light you have if your friggin eyes are bad you need glasses. ha-ha
      I always tell myself I would rather need just reading glasses then have to wear them all the time. Reg eyesight is good, thank God.
      • femaster
        • May 2011
        • 1508
        Just wanted to add a bit to this thread. This is a common problem with the earlier 4e units that had the black rollers. The rollers were changed out to clear (white?) later on and the toner doesn't build up on these. For those that have experienced the buildup, it WILL return again.
        What I've been doing is LOWERING the fuser temp by 1 notch (I believe it is -5 degrees), and have not had any further issues with toner buildup on the rollers. I also haven't had any problems with toner adhesion on the paper, so unless your customers are running thicker paper at the wrong setting (plain), you should have no issues with making this settings change.
        • kenpio
          • Dec 2015
          • 201
          #19
          Just thought I would say, was at a customer and pulled this off the exit roller of a BH364e.
          KEN
          • femaster
            • May 2011
            • 1508
            #20
            I actually just had to clean off 3 of the 4 rollers in a C284e this past Thursday. Very low volume machine, so this uint had never gotten my fuser temp modification as this was it's first service call; crinkles on pages and noise. Lowered the temp and don't expect to see that problem again.
            • copiertec
              • Jan 2016
              • 2210
              #21
              What temp are you lowering it to?
              • tsbservice
                Field tech
                • 8020
                #22
                You thanked him for that answer in his previous post of the thread
                • copiertec
                  • Jan 2016
                  • 2210
                  #23
                  you are correct...senior moment on my part?
                  • allan
                    RTFM!!
                    • 5462
                    #24
                    Originally posted by qbert69
                    I'd rather see DIRECTLY & CLEARLY what I'm looking at than not!!! I've fixed many a problem all because the previous tech(s) didn't have the light where they were looking and missed a simple critical detail!!! My favorite headlights are the USB rechargeable ones!!! Two used in rotation! While one is on my head, the other is in my van, charging whilst driving!!! If you haven't tried it, don't knock it!!![emoji41][emoji1303]
                    Sent from my SM-N950U1 using Tapatalk
                    Yea they work great and will do 500 cycles on a single battery!
                    This hilight brand is cheap and reliable so far.
                    Whatever
                    • tsbservice
                      Field tech
                      • 8020
                      #25
                      Maybe or...not. I see in your posts only senior...tech
                      • Lync
                        • Feb 2016
                        • 47
                        #26
                        I have had this happen when they print a lot of labels setting the stock as plain. Get them to print labels as thick 1. (Or appropriate settings for other thick stock)
