C258 Set default tray
  • JDR
    • Jan 2015
    • 82
    Hi guys,
    I have an issue with the default tray fro internal prints.
    For example, if i print the demo sheet of the bird, the tray set by default is the number 2. I'd like for each internal prints, tray 1 be selected. Anyone knows how to ?
    i have tested commun settings for paper settings : utility > user settings > system.
    I tried in user settings > print settings > paper settings > default tray > 1.
    Dunno where...
    • 15068
    Re: C258 Set default tray
    There is a selection that reads "print lists". Or something like that. It should allow you to select a tray from there.
    • jalaoly
      • Jul 2014
      • 10
      Hi! Guys
      user settings > system settings > paper tray setting>print list and choose your paper tray
      • JDR
        • Jan 2015
        • 82
        well i shoud not be understandable.
        I know how to choose a tray for an internal print.
        The issue is when (for example) i want to print a bird, without touching the screen, the tray 2 is selected.
        I would like the tray 1 to be selected (by default).
        how to fix that ? (maybe is that a softsw)
        • jalaoly
          • Jul 2014
          • 10
          ok
          if you are on select auto to copy mode and on the printer driver
          user settings > system settings > paper tray setting>auto tray select setting
          auto tray select=>select all tray excep by-pass
          tray priority => up tray 1 first.
          • JDR
            • Jan 2015
            • 82
            Sorry, still the same :/
            • tsbservice
              Field tech
              • 8081
              I have no idea but if other don't work, you can try this:
              [Utility]
              [Administrator Settings]
              [Copier Settings]
              [Specify Default Tray when APS Off]
              Select:
              [Default Tray] Switches to Tray1.
              • jalaoly
                • Jul 2014
                • 10
                hi
                On copy mode,select tray 1
                user settings>copier setting>default copy setting>current setting
                • kingarthur
                  • 1399
                  When I print the "bird" demo sheet, the machine asks which tray i want to print from.....
                  • emujo2
                    • Mar 2017
                    • 1579
                    Print list selection is for test prints, IP config page, PS PCL fonts, fax report..You can default these to whichever tray you wish and posted a few comments above.
                    • Synthohol
                      Certified Konica Expert
                      • 5922
                      plus that tray has to be set to PLAIN.
                      • JDR
                        • Jan 2015
                        • 82
                        Issue solved.
                        Data clear + user settings > system settings > paper settings > tray 1.
                        At the begining, even if i did choose tray 1, it still prints with tray 2.
                        Thanks all for your replies.
