Bizhub C308 c-2554 error
  • copier tech
    • 8231
    Hi all,
    Anyone seen this before? magenta level is at 9.5% during a print run will throw C-2554.
    Removing the magenta toner & doing a run the level will drop until machine calls for magenta toner. However when the toner is installed the level goes back high & throws the code again!
    I've only ever seen low toner dens not high.
    All image units are nearly new as is the transfer unit (replaced about a month ago)
  • copyman
    Owner / Technician
    • Sep 2005
    • 4786
    Re: Bizhub C308 c-2554 error
    Not sure I can be much help. You are right it's usually dev is low from dumping due to overlife consumables, HV leak, etc.
    The only time I saw it high is when I try to recover a dev unit that has dumped by adding dev from another used dev unit. I always end up pouring in too much dev and although it doesn't code is will show 9 +% which as you know is suppose to be in the 6.5 range. At that point I run 11x17 half tones until the # drops to around 7. Then I run some regular color pages, turn off and on a few times and it "usually" stabilizes and stays around 6-7%
    If anything else comes to mind I'll post it.
    Good luck
    • REGSIS
      • May 2016
      • 440
      Hi all,
      Hmmmm!
      Try to update the firmware.
      If that doesn't work you can try TCR sensor from another machine; or swap from other dev unit of the same machine and see if code move to that color.
      On 4 series TCR sensosrs were the same for all colors, I presume it's like that on 8.
      Maybe they are even the same on both series (didn't checked).
      • copier tech
        • 8231
        Originally posted by REGSIS
        Hmmmm!
        Updated firmware & set function version to 4.3.
        Cleaned the TD sensors removed the toner & ran full page magenta until M level returned to normal 6.5% then ran initialise + stabilise.
        But when putting the M toner back in & running prints the level went back to 10% & threw C-2554 again.
        Bit stumped have ordered a new mag dv unit to go back with.
        • tsbservice
          Field tech
          • 8075
          I'm with REGSIS on this issue. Your dev unit TCR sensor probably went flaky.
