Bizhub C224 - SSO SSL
  • amcargo
    • Jan 2020
    • 6
    [Misc] Bizhub C224 - SSO SSL
    Hello, I'm trying to use the SSO with the Bizhub C224 but allways when try to join to the domain get error; we are using the the AD with SSL can be this the problem?? The LDAP can be configure without problem but the SSO allways get server error can't connect.
    Thanks for your help and time.
  • Synthohol
    Certified Konica Expert
    • 5922
    Re: Bizhub C224 - SSO SSL
    machine old and discontinued.
    does not adhere to current security levels required by current servers.
    perfect opportunity to upgrade machine to currently supported models.
    • amcargo
      • Jan 2020
      • 6
      Then is not supported for this model?? I know is not a very new model but is the machine I have
      • Bix
        • Apr 2018
        • 1421
        An attempt could make it updated to the latest firmware, otherwise it is not supported with the new security protocols.
        • emujo2
          • Mar 2017
          • 1579
          The C224 was probably keyed to server 2008..and yes, current servers would block this all day probably just due to unsupported security protocols..TLS 1.2 ie..But, I have a C468 that I am unable to connect to my 2012 servers due to constraints placed upon the company network. My question is why would you want to join a MFP to your domain?? To take advantage of scanning w/o having to sign in? Or are you trying to print with authentication and windows IDs? Ed
          • amcargo
            • Jan 2020
            • 6
            The idea is to use SSO to avoid having to configure the driver for each user and create the user by hand
            • copier tech
              • 8236
              There is 'version up' firmware available for the C224 this 'upgrades' your old 4 series to a 4e series this may be a solution for you.
              • rrrohan
                • Sep 2011
                • 1977
                What i normally do when i cant get SSO working is just setup user auth with AD names and no password.
                Then install universal driver and in admin section lock the user auth setting so it cant be changed.
                Since the users use cards to login at copier they never even know the accounts arent protected by password
                Sent from my SM-G955F using Tapatalk
                • amcargo
                  • Jan 2020
                  • 6
                  I ask to my provider and see if works. Thanks !!
                  • amcargo
                    • Jan 2020
                    • 6
                    How I know which firmware version I have installed ??
                    ROM Version
                    MFP Card Version A5C10Y0-F000-G20-G9(00)
                    MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
                    MFP Controller Linux Base Linux-2.6.26.8-rt16
                    MFP Controller Kernel Program A5C10Y0-1C00-G00-61
                    MFP Controller SubSet A5C10Y0-1F00-G00-J2(00)
                    MFP Controller A5C10Y0-0100-G20-G9(00)
                    Operation Panel Message Data A5C10Y0-8100-G00-G0
                    Fax Board Controller1
                    Fax Board Controller2
                    Fax Board Controller3
                    Fax Board Controller4
                    Engine Parameter A5C10Y0-0054-G00-01
                    Engine BOOT A5C10Y0-0055-G00-00
                    Scanner A5C10Y0-0023-G00-30
                    Printer A5C10Y0-0050-G00-26
                    ADF A3CF0Y0-0024-G00-12
                    Finisher
                    RU
                    ZU
                    Panel CPU A55V0Y0-8900-G60-00
                    DSC1
                    DSC2
                    Loadable Device Driver1
                    Loadable Device Driver2
                    SD
                    Voice Data
                    Movie Data A5C10Y0-C000-G00-30
                    Dictionary Data
                    OCR Library
                    Panel Sound Data A5C10Y0-C200-G00-00
                    MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01
                    MFP Controller PIC Image Parameter A5C10Y0-8A00-G00-01
                    MFP Controller System A5C10Y0-1000-G20-G9(00)
                    MFP Controller Print Controller A5C10Y0-3000-G01-04
                    MFP Controller Print Controller Font A5C10Y0-3F00-G01-00
                    MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81
                    MFP Controller MIO A5C10Y0-5000-G00-H4(00)
                    MFP Controller PIC A5C10Y0-8200-G00-B1
                    • emujo2
                      • Mar 2017
                      • 1579
                      That SSO functionality also requires special drivers that pull the windows credentials for printing... E
                      Sorry no special drivers, just enabling SSO under the authentication tab. E
                      • amcargo
                        • Jan 2020
                        • 6
                        I know, this is the driver has the SSO ready and I'm using on Windows 10
                        • tsbservice
                          Field tech
                          • 8081
                          ROM Version
                          Finisher
                          RU
                          ZU
                          DSC1
                          DSC2
                          SD
                          Voice Data
                          Dictionary Data
                          OCR Library
                          You have G20-G9 FW
