Fiery e100-06 Internal installation manual (c754)
  • vertigosystems
    • Feb 2019
    • 28
    Is there anywhere I could get my hands on an install guide for the Fiery E100-06 for an internal installation on the C754? There are brackets included that I've spent hours trying to tetris them into some position that would allow them to hold the unit in position so it would be in alignment with the plastic faceplate that appears to be designed specifically for it.
    Any documentation or even a picture of a properly installed on would be a great help.
    I could also use the system install CD for v1.2 if anyone is able to point me in the right direction. I signed up with EFI, and contacted them but they seem unwilling to assist, referring me to talk to KM.
  • Synthohol
    Certified Konica Expert
    • 5807
    Re: Fiery e100-06 Internal installation manual (c754)
    first, here are the install instructions.
    second the system software is programmed for that MFG so yes it would have to be konicas VERSION of the IC-414.
    third if you want a copy of it, try becoming a contributor, i hear they get the files they need with a link in a PM.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4643
      Not sure what you mean about "Internal installation" but K/M Fiery's connect to back of machine not internally.
      • Synthohol
        • 5807
        On the bigger machines the fiery is installed in a cavity behind the lower rear panel.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4643
          Ha-ha. I thought last time a fiery was in a cavity inside kon/min model was the Di-750. Well that's the last time I saw one. After that model the Di5510 had it hanging on uppder rear. Shows how little I worked on the bigger machine. Mostly 50 ppm or less segment. Currently biggest machine I work on is C754.
          • vertigosystems
            • Feb 2019
            • 28
            Much appreciated, and consider me contributed. It's been a while since I've had to seek out info that I literally couldn't find and this 414 guide was nowhere to be found on google regardless of the quote blocks.
            Any chance I could request the system CDs for 1.2 for this unit?
            • Synthohol
              • 5807
              check your PMs.
              thanks for contributing!!!
              • vx07
                • May 2020
                • 2
                Any chance I could request the system CDs for 1.2 for ic-414?
                tnx
                • Synthohol
                  • 5807
                  PM sent
                  • radd
                    • Jun 2020
                    • 63
                    @Synthohol
                    Could I also trouble you for the 1.2 CD's IC-414. I get to play around with one on Monday
                    //radd
                    • Synthohol
                      • 5807
                      done.
                      • radd
                        • Jun 2020
                        • 63
                        done.
                        Thank you sir!
                        Much appreciated
                        • abcraflatac
                          • Jun 2020
                          • 2
                          I have a E100 60-55C-KM PS 1.2 and I apparently managed to break it while installing patches. I would greatly appreciate those CD's and any corresponding documentation as well, since I cannot access my technician due to this COVID thing. :-(
                          • Synthohol
                            • 5807
                            what is the fiery model? IC-XXX?
                            • abcraflatac
                              • Jun 2020
                              • 2
                              Yes, sir - that's an IC-414 running inside a C754e. Please see attached. And thank you for your interest, by the way. :-)
                              XeroxScan_24062020133852.PDF
