Firmware for C364e A5C10Y0-F000-G20-M1
  • rogernav
    • Jan 2020
    • 4
    Can anyone provide me with this Firmware? A5C10Y0-F000-G20-M1
    I tried with the Gxm-m1 and I am getting a Bad Memory error after I did the update.
    Needed Urgently.
    Re: Firmware for C364e A5C10Y0-F000-G20-M1
    I tried with the Gxm-m1 and I am getting a Bad Memory error after I did the update. Needed Urgently.Thanks
    have you cleared memory?
    what exactly HAVE you done?
    • tsbservice
      Field tech
      • 8053
      Never heard about "Bad Memory error" after FW update. Neither that some specific FW will fix it.
      What have you done to poor machine?
      • rogernav
        • Jan 2020
        • 4
        I simply used the USB upgrade after putting the files in the stick.
        No other process..
        I need the other firmware files so that I can try that I e ...the system was working before the firmware upgrade ...I think the message is it referring to the removed USB stick after the upgrade.
        Please send me a link or download for the firmware file requested if you have it?
        • Bix
          • Apr 2018
          • 1421
          Hello,
          make a donation to the forum, you have a good chance that you will receive the required firmware.
          • rogernav
            • Jan 2020
            • 4
            I have called Minolta this morning for the Firmware and they say My machine, built in 2013, is out of Contract and they cannot help me.
            They have to provide a tech to put the firmware on a USB stick and stick it in the machine as if I cant! Frustrating.
            Please does anyone have this Firmware...it has my MFP down for a day already.
            I need the G20-M1 Firmware for the BizHub C364e
            Thanks.
            • Synthohol
              Certified Konica Expert
              • 5892
              ck your PMs.
              thank you for contributing!!
              • Synthohol
                • 5892
                remember, 4G or smaller flash drive and the contents of the ROOT of the drive is to contain the contents of the subfolder.
                on the root you should see APP, BIN, FW, etc folders and the files as well.
                • SeniorTch
                  • Jun 2017
                  • 117
                  Hi gays you can help me with this firmware I need
                  • haryo
                    • Mar 2020
                    • 2
                    i send you a pm
                    • Hanja
                      • Apr 2020
                      • 1
                      Latest Firmware for C554e
                      Could someone please assist with latest firmware for Bizhub C554e.
                      • Synthohol
                        • 5892
                        ck your PMs
                        • lithal neveen
                          • Jan 2024
                          • 1
                          hi guys i also need bizhub c364e firmware
                          • copier tech
                            • 8200
                            Happy to help. Please contact us via either website below.
