Bizhub C-308 with FS-534 finisher...
  • Oystercopy
    • Oct 2009
    • 623
    Customer getting frequent jam codes and paper stops/bunches up between exit and the internal finisher. The codes are 3201 and 7217, consistently.
    Any help appreciated!
    OC
  • tsbservice
    Field tech
    • 7977
    Re: Bizhub C-308 with FS-534 finisher...
    Check operations of Gate switch solenoid (SD3).
      • 22999
      Didn't the 4e series machines do this when the exit section bushing seized up for lack of lubrication? =^..^=
      • Oystercopy
        • Oct 2009
        • 623
        So, does this series SHARE the same solenoid/exit issues that the -4 series had? I've never seen this happen before in the -8 series, only the -4....??
        OC
        • tech51
          • 846
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            OC
            I'm confused. The title says FS-534 which is the standard external floor finisher but you mention the internal finisher unless you meant the horizontal unit instead.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • Oystercopy
              • Oct 2009
              • 623
              My apologies, it is an internal FS-533 Finisher...
              And can someone tell me which exit bushings we're talking about? Are they metal/brass and is that why they dry out and cause drag?
              OC
              • tech51
                • 846
                OC
                As I previously said it’s the exit rollers on the main body. They are plastic bushes.
                I give them a squirt of ptfe lube and that generally does it.
