Customer getting frequent jam codes and paper stops/bunches up between exit and the internal finisher. The codes are 3201 and 7217, consistently.
Any help appreciated!
OC
Didn't the 4e series machines do this when the exit section bushing seized up for lack of lubrication? =^..^=
So, does this series SHARE the same solenoid/exit issues that the -4 series had? I've never seen this happen before in the -8 series, only the -4....??
OC
OC
I'm confused. The title says FS-534 which is the standard external floor finisher but you mention the internal finisher unless you meant the horizontal unit instead.
Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
