Bizhub 423 Tray 1 jam
  • gideon
    • 276
    Paper is jamming before reaching the transport unit (feed out of the tray 1").
    Tray 2 feeds fine.
    New OEM rollers
    New feed clutch
    Adjust loop
    Can't see anything wrong with guides etc
    I have the manual
    Any idea?
  • allan
    RTFM!!
    • 5445
    Re: Bizhub 423 Tray 1 jam
    If you replaced the feed unit with one from a 363 or 223 then you are missing the additional sensor used by the 423 that would be present on the unit.
    The units without the reflective sensor will have yellow wiring and 3 unused pins on the connector.
    The one for the 423 will have grey or purple wiring and all the pins on the connector are in use.
    Whatever
    • gideon
      • 276
      This tray is original on the copier, it worked fine before.
      • Synthohol
        Certified Konica Expert
        • 5463
        Everything he just said plus scuff the shafts and clean out the one way black bearings.
        • tsbservice
          Field tech
          • 7635
          Two wise man spoken, this time my vote going with second
          • allan
            RTFM!!
            • 5445
            What is the jam code?
            J-1101?
            J-2002?
            J-3003?
            The meter count on the box?
            Had it where the clutches can pull a paper coming from a lower tray but not if it needs to pull it from around a curve.
            Whatever
            • elmaligno
              Expert technician KM
              • Oct 2009
              • 251
              Tray 2 feeds fine.
              New OEM rollers
              New feed clutch
              Adjust loop
              I have the manual
              Any idea?
              You have the problem at the registration roller. Problably you have J3003. This roller/clutch pulls the sheet by his own only when it is feeded from tray 1. For the other trays, the sheet is helped to rise up to the registration with the others vertical rollers.
              Field technician since 1994
              • gideon
                • 276
                J-1101?
                J-2002?
                J-3003?
                Jam is 11-01 copier has 325k
                The gear clutches are lubed, paper leading edge is jamming about 1/4" pass the clear guide, it can be pull out with ease. There is no obstruction on the guide nor dent on the leading edge.
                Thanks for your input.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4217
                  Ive had this before and killed me. Tray 2 feeds fine, tray 1 paper stops exact same place everytime.
                  Fix: Remove the transfer roller unit and when you put it back in make sure the clear guide is behind the reg rollers. I never do this but I'm 100% sure this is your problem.
                  • gideon
                    • 276
                    I'll check it out, thanks.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4217
                      Just to be clear you remove the reg unit that has the transfer roller on it. I called it the transfer unit but in serv manual it's called reg unit.
                      • allan
                        RTFM!!
                        • 5445
                        Lubrication! No do not lubricate anything on those assemblies.
                        How far doses the paper get fed?
                        Yea hate it if i get the callback that double sided jams every print. Now always make very sure the guide is in place.
                        Whatever
                        • gideon
                          • 276
                          Thanks to you all.
                          Copyman you fixed it, it was the mylar edge got under the transfer roller unit.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4217
                            Thanks to you all.
                            Good to hear it worked. My 100% "sure it will fix guarantee" is still intact, ha-ha. I usually don't say that unless 100% sure.
