C368
  • copyman
    Owner / Technician
    • Sep 2005
    • 4213
    C368
    I have a customer that buys off lease copiers from me and their IT people set them up. Until this last time they always bought C224e's and never any issues. I just sold them a C368 with only 20K on it and they say it prints and copies fine but cannot SMB scan. Like I said their IT people have setup maybe 20 of the C224's and never needed any assistance. Is there anything different from C224 with setting up SMB scanning on the C368? Not sure if it has anything to do with it but the C368 does have the wireless network option installed but copier is hard wired with Cat 5 and printing ok. If it could have anything to do with it I'll remove wireless card since machine is hard wired and not being used.
    Figured I would ask here before paying my IT guy to go have a look. Haha I'm not trying to skate free after the sale but I low ball the price with this customer because they pick up machines and do the setup themselves.
    Thanks in advance
  • Bix
    • Apr 2018
    • 1421
    Re: C368 smb wireless card installed
    Hi copyman, it may be that the SMB scan goes wrong in the wireless network which is perhaps blocked on one side of the firewall. It would be useful to ping from the MFP to PCs or perform a reference scan to locate folders directly from the C368. Descriptions of Functions / Utility Keys
    • copyman
      Owner / Technician
      • Sep 2005
      • 4213
      Re: C368 UPDATE
      I had my Kon/Min IT guy stop by today and this is what he sent me:
      Hope this makes sense because I'm old school "repair" tech not IT and it's a different language to me
      Thanks for any help. Since I just sold it hate to have to go through the hassle of swapping out machine, etc.
      • Synthohol
        Certified Konica Expert
        • 5458
        Re: C368
        ive seen that, add share permissions to the sub folder as well.
        that usually works.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4213
          Re: C368 2nd UPDATE
          Hi tried what was posted and still not working.
          I went out today to update firmware. Brought 4 different USB sticks with the latest F/W. This was procedure in serv man, Hold down (red)stop while turning on with USB stick in port by control panel. None worked. All the USB jump drives were used with no problems in the "4" series models.
          It did say in serv man if don't work something about going into admin mode (security settings) than next step was (USB connection permission setting) but that tab is missing? Spent over an hour looking in serv manual for admin security settings, enhanced serv mode, etc. Couldn't find anything to maybe unlock the admin mode so the tab shows up. Tried changing a lot of settings and when they didn't work put setting back where they were.
          What am I missing besides a brain
          • tsbservice
            Field tech
            • 7635
            Re: C368
            Check that current FW version is reflected via right switch 25 setting.
            Also try that with front door open.
            • REGSIS
              • May 2016
              • 434
              Re: C368
              I'm not sure what is different, but YES it is different.
              In C224e and Win 7 days I would share a folder give access to EVERYONE and it worked.
              Since 7 and 8 series I need to do it with username and password inputed otherwise it won't work.
              MFP:
              Computer hostname
              Shared folder
              Username
              Password
              Win machine:
              1. Network should be identified as PRIVATE (HOME or WORK)
              If nework is PUBLIC scanned file could be blocked by firewall.
              2. Network discovery, file and printer sharing, public folder sharing should be ON.
              3. Password protected sharing ON. You can turn if OFF but with next windows update it will be ON very soon.
              Search for "windows features" and enable SMB/CIFS 1.0 server and restart machine. Uncheck autoremoval option.
              Check for installed internet security suite which usually has it own firewall which blocks outside access.
              I usually don't set up password if users don't already have it. I create a new user (with password) and share a folder with him and the owner. On MFP I input newly created username and password.
              So with username and password inputed and all above things checked it worked everytime.
