C364 Display Keyboard
  • tulintron
    • Jul 2014
    • 668
    Hello everyone.Whenever I update the C364 printers, I lose the Display Keyboard function on the touch panel.
    I know that in the "e" series printers it is fixed.
    In the series non "e" appear until they update. After the updates, it just disappears.
    Any firmware that fixes or just settings?
    Thank you for now.
  • copier tech
    • 8165
    Re: C364 Display Keyboard
    Thank you for now.
    If your machine had the "version up" firmware installed & you update with regular non e firmware you will downgrade the non e machine.
    To enable the on screen keypad you need to reinstall the version up firmware again.
    • Synthohol
      Certified Konica Expert
      • 5840
      if its a NON-E then doesn't the whole panel slide over to expose the keypad.
      no need for "display keypad" if thats the case. its not needed.
      • tulintron
        • Jul 2014
        • 668
        Is the correct name for this firmware version "version up", or does it have another name?
        I can't find it in my folders ...
        • copier tech
          • 8165
          Have a read of this bulletin for further info.
          Version Up Firmware Technical Information Rev4.pdf
